设备用途http://www.liuxinxing.com/
本设备为双面脉冲热压机,适用于各种液晶屏(LCD PANEL)触摸功能玻璃(SENSOR GLASS)FPC、TAB、FOC生产工艺中双面本压工艺,以及FPC与PCB板的脉冲焊锡工艺。
设备功能特点
Machine Feature
设备气缸采用进口低摩擦气缸,保证气缸下压精度。
Machine is equipped with
热压头采用进口钛合金材料,热压头受热均匀,热稳定性好
Bond head is made of
PLC控制系统,人机界面操作。
PLC controlling system, human-machine operation interface.
上下脉冲同时加温,用来电容触摸屏双面FPC本压工艺
Top and bottom pulse heating mode is specialized in FPC double sides main-bonding for CTP touch panel.
设备自带上下两组自动卷皮结构。
Machine is equipped with top and bottom silicone gel auto-rolling devices.
固定式双工位工作平台,设备精度高
Fixed double work stages, high precision.
设备技术参数 Technical Parameters
输入电源 Input Power |
AC220V 2500W |
工作气压 Work Pressure |
0.4-0.6Mpa |
加温方式 Heating Mode |
上下脉冲式加热 Top and bottom pulse heating |
压头尺寸 Bond Head Size |
60mm*1.8mm可选配 Bond head size is customized. |
设备工作方式 Work Mode |
固定式单工作方式 Fixed single work stage |
设备工作周期 Circle Time |
设备周期10s-15s |
工作台尺寸 Work Stage Size |
130mm*150m可选配 Work stage size is customized. |
工作平台调节方式 Work Stage Adjustment |
千分尺可调X.Y.Q可调Micrometer adjust X,Y, θ direction. |
脉冲输出温度 Pulse Output Temperature Accuracy |
±2° |
设备重量 Machine Weight |
250KG |
