PW-M1030
设备用途http://www.liuxinxing.com/
本设备为ACF贴附机,适用于各种液晶屏(LCD PANEL)触摸功能玻璃(SENSOR GLASS)FPC、TAB、FOC生产工艺中ACF预贴工艺,取料放料手工完成,ACF贴附设备自动完成。
设备特点
Machine Feature
设备气动原件产用日本SMC滑台气缸,气缸压力均匀,保证设备精度。
Machine adopts Japanese SMC cylinder with even pressure to ensure high precision.
压头采用进口特殊材料,受热均匀贴附无气泡
Bond head is made of
PLC控制系统,人机界面操作
PLC controlling system, human-machine operation interface.
热压头附有自动卷硅胶皮装置(可根据客户要求选配)
There is auto silicon gel rolling device. (Option is customized.)
工作平台前后移动有气缸驱动,线性导轨导向,移动平稳,保证设备精度
Work Stage front and rear movement is driven by cylinder. Linear guide rail, ensure movement stability and high accuracy.
设备技术参数Technical Parameter
输入电源 Input Power |
AC220V 300W |
工作气压 Work Pressure |
0.4-0.8Mpa |
加温方式 Heating Mode |
恒温加热 Constant Heat |
工作方式 Work Mode |
单工位固定式工作 Fixed single work stage. |
压头尺寸 Bond Head Size |
60mm*1.8mm可选配 (Bond head size is customized.) |
设备工作周期 Circle Time |
3s-6s |
工作台尺寸 Work Stage Size |
130mm*130mm |
贴附精度 Tacking Accuracy |
±0.1mm |
设备重量 Machine Weight |
250kg |
