备用途http://www.liuxinxing.com/
本设备为双工位脉冲热压机,适用于各种液晶屏(LCD PANEL)触摸功能玻璃(SENSOR GLASS)FPC、TAB、FOC生产工艺中脉冲预本压工艺,以及FPC与PCB板的脉冲焊锡工艺。
设备功能特点
Machine Feature
设备气缸采用进口低摩擦气缸,保证气缸下压精度。
Machine is equipped with low friction cylinder to ensure cylinder go down precision.
热压头采用进口钛合金材料,热压头受热均匀,热稳定性好。
Bond head is made of
PLC控制系统,人机界面操作。
PLC controlling system, human-machine operation interface.
三压头循环式工作,中间预压,两边脉冲本压
Three bond heads will work alternatively. Middle bond head is used for pre-bonding. Two side bond heads are used for pulse main-bonding.
设备自带三组自动卷皮结构。
Machine is equipped with 3 sets auto silicon gel rolling devices.
左右移动工作平台,双导轨辅助设备移动平稳。
Left and right work stage is assisted by double guide rails to ensure movement stability.
设备技术参数 Technical Parameter
输入电源 Input Power |
AC220V 3000W |
工作气压 Work Pressure |
0.4-0.6Mpa |
加温方式 Heating Mode |
双工位脉冲式加热 Double work stages with pulse heating system. |
压头尺寸 Bond Head Size |
60mm*1.8mm可选配 Bond head size is customized. |
设备工作方式 Work Mode |
左右移动式工作方式 Work stage move left and right. |
设备工作周期 Circle Time |
设备周期10s-20s |
工作台尺寸 Work Stage Size |
150mm*180mm可选配 Work stage size is customized. |
工作平台调节方Work Stage Adjustment |
千分尺可调X.Y.Q可调Micrometer adjust X,Y, θ direction. |
移动配置 Movement Configuration |
伺服电机加双导轨辅助左右移动 Servo motor and double guide rails assist left and right movement. |
设备重量 Machine Weight |
300KG |
