设备用途http://www.liuxinxing.com/
本设备为双工位恒温本压机,适用于各种液晶屏(LCD PANEL)触摸功能玻璃(SENSOR GLASS)FPC、TAB、COF生产工艺中本压绑定工艺.
设备功能特点
Machine Feature
设备气缸采用SMC气缸,保证气缸下压精度。
Machine is equipped with low friction cylinder to ensure cylinder go down precision.
热压头采用进口材料,热压头受热均匀,热稳定性好
Bond head is made of
PLC控制系统,人机界面操作。
PLC controlling system, human-machine operation interface.
双压头固定式工作,两边恒温本压
Fixed double work stages, constant heat main-bonding.
设备自带两组自动卷皮结构。
Machine is equipped with 3 sets silicone gel auto-rolling devices.
设备可适用于250mmFPC本压工艺。
The machine is applicable to bonding 250mm FPC onto substrate.
设备技术参数 Technical Parameter
输入电源 Input Power |
AC220V 3000W |
工作气压 Work Pressure |
0.4-0.6Mpa |
加温方式 Heating Mode |
双工位恒温式加温Double work stages with constant heat system. |
压头尺寸 Bond Head Size |
220mm*3.0mm可选配 Bond head is configurable. |
设备工作方式 Work Mode |
平台固定式工作方式 Fixed double work stages |
设备工作周期 Circle Time |
设备周期10s-20s |
工作台尺寸 Work Stage Size |
250mm*220mm可选配 Work stage size is configurable. |
工作平台调节方Work Stage Adjustment |
千分尺可调X.Y.Q可调Micrometer adjust X,Y, θ direction. |
FPC适应长度 |
110mm或250mm (configurable) |
设备重量 Machine Weight |
300KG |
