| LM215WF3-SLC1 SPECIFICATION 浏览次数:360 更新日期:2011-10-15 14:33 |
| LM215WF3-SLC1常见参数 LM215WF3-SLC1详细参数 | |
| LM215WF3-SLC1基本参数 | |
| 制造商(Productor) | LG |
| 产品型号(MODEL) | LM215WF3-SLC1 |
| 屏尺寸(Size) | 21.5英寸 |
| 分辨率(Resolution) | 1920x1080 |
| 分辨率简称(Resolution Name) | FHD |
| 显示比例(Display scale) | 16:9 |
| 像素排列(Pixel Arrangement) | RGBVerticalStripe |
| 点距(Pixel Pitch) | 0.083x0.248 mm |
| 产品组成(Panel Composition) | 液晶屏 |
| 面板类型(Technology) | a-Si |
| 主要用途(Applications) | 电脑显示器 |
| 显著特征(Panel Features) | 表面雾面,广视角,白光LED背光,宽屏 |
| LM215WF3-SLC1光电参数 | |
| 显示模式(Display mode) | IPS,常黑显示,透射式 |
| 亮度(Luminance) | 250 nits |
| 对比度(Contrast Ratio) | 1000 :1 |
| 颜色(Color) | 16.7M(6bit+HiFRC) |
| 响应时间(Response) | 14(GtoG) ms |
| 可视角度(Viewing Angle) | 89/89/89/89 (上/下/左/右) |
| 最佳视角(The Best View) | 对称 |
| 白场色度(White Field Chroma) | X:0.313;Y:0.329 |
| 白场变动(White Field Dynamic) | 1.33(Typ.)(9points) |
| 扫描频率(Scanning Frequency) | 60Hz |
| 反转扫描(Reverse Scan) | No |
| 信号类型大类(The kind of Singnal) | LVDS |
| 接口类型(Interface) | LVDS(2ch,8bit) |
| 信号接口定义(Singnal Interface Definition) | LVDS-30P2C8B-160B |
| 驱屏电压(Drive-screen voltage) | 5.0V |
| 面板输入电流(Input Current) | 1063/1223mA(Typ./Max.) |
| 信号接口类型(Kind of Singnal Interface) | Connector |
| 信号接口品牌(Brand of Singnal Interface) | UJU |
| 信号接口型号(Model of Singnal Interface) | IS100-L30O-C23 |
| 信号接口脚距(Pitch of Singnal Interface) | 1 mm |
| 信号接口数量(Quantity of Singnal Interface) | 1 pcs |
| 信号接口脚数(Pin of Singnal Interface) | 30 pins |
| LM215WF3-SLC1结构参数 | |
| 工作温度(Operation Temperature) | 0 C ~ 50 C |
| 存储温度(Storage Temperature) | -20oC ~ 60oC |
| 面板重量(Weight) | 1.30/1.37 kg |
| 表面处理(Surface Technology) | 雾面,Hardcoating(3H) |
| 显示区域(Active Area) | 475.2x267.3 mm |
| 可视区域(Display Area) | 478.8x271.3 |
| 外形尺寸(Outline) | 495.6x292.2x10.2 mm |
| 触摸屏(Touch Panel) | 无 |
| 灯管位置(CCFL Position) | 侧入式光源(底部) |
| 背光类型(Backlight) | 白光LED |
| 灯管数量(Lamp Number) | 4strings pcs |
| 灯管形状(CCFL Shape) | 4串 |
| 背光寿命(Life Time of Lamp) | 30K Hours |
| 单一灯管电压(Voltage of Lamp) | 41.6±2.6 |
| 单一灯管电流(Current of Lamp) | 110/120mA(Typ./Max.) |
| 内置灯管驱动器(Driver of Backlight) | 无 |
| 背光接口类型(Kind of Backlight Interface) | Connector |
| 背光接口品牌(Brand of Backlight Interface) | YEONHO |
| 背光接口型号(Model of Backlight Interface) | 10019HR-H06B |
| 背光接口数量(Quantity of Backlight Interface) | 1 pcs |
| 背光接口定义(Backlight Interface Define ) | BLE-6PINS-CCAACC |
| LM215WF3-SLC1包装及生产状态 | |
| 每箱数量(Quantity Per Box) | 12 pcs |
| 包装箱尺寸(Size of the Box) | 365x315x578 mm (长×宽×高) |
| 开始量产时间(Date Begin Producing) | 2010,Q3 |
