TDC3000系统一些常见卡件部件号如下:
51304516-200,51305348-100,51304584-100,51401583-100,
51304362-150,51309152-100,51304485-100,51304441-100,
51402615-400,51401583-100,51196654-100,51402089-100,
51304685-150,51304511-100,51304511-200,51304754-150,
51304337-150,80363969-150,51305072-100,51305072-200,
51309152-175,51309204-125,80363969-100,80363969-150,
80363975-150,51403422-150,51309276-150,51304754-150,
51204172-175,80363975-150,51204162-175,51204160-175,
51304516-250,TC-IXR061 ,TC-ODD321, TC-IDD321,TC-OAV081,
TC-IAH161,TC-PCIC02,51304648-100,51304441-100,51301364-100,
51405907-175,51191052-100,TC-CCR013,TC-OAV081,TC-ODD321,
TC-FPCXX2,51304754-150,80363969-150,51402625-175,80363972-150,
80363975-150,51304362-150,51402089-100,51401583-100,51403299-200,
51309204-175,51204172-175,51304441-175,51204160-175,51204162-175,
51309204-175,51304084-100,51304754-100,51304368-100,51304476-100,
51304477-100,51303968-100,51401946-10051201645-800,51309152-175,
51309204-175,MC-PAIH03,MC-PAOY22,MC-PDIS12,MC-PDIY22,MC-PDOY22,
MC-PLAM02,51402089-100,51401583-100,51403299-200,MC-TLPA02,
MC-TAOY22,MC-TDID12,MC-TDIY22,MC-TDOY22,MC-TLPA02
51303979-550,51304518-150,51401052-100,51309152-175,
51304516-100,51304453-150,51304476-125,51304441-125,
51304650-100,51309218-125,51304477-100,51401491-100,
51304485-100,51304487-100,51304672-100,51304754-150,
51304754-100,51401277-200,51401560-100,51196654-100,
51401286-100,51197015-300,51197019-100,MP-ZHMU18-100,
MP-ZHMU15-100,MP-ZIP101-100,51197079-100,51191561-100,
51308093-300,51308094-300,30754661-021,51190582-210,
51107144-101,30754661-014,MU-NKDK01,MU-KFTA03,MU-NTAP02
51201394-100,MU-NKD002,51195153-002,MU-NKT010,51195199-010,
51304754-150,51303979-500,51304493-200,51304518-100,51304685-100,
51304362-300,51402615-800,51402615-400,51304511-100,51304511-200,
51304542-100,51304542-200,51304337-100,51309223-175,51309204-100,
APM 51303979-550 APM I/O Link Driver, CC 2
APM 51304493-250 APM MODEM CC, R400 3
APM 51304518-150 APM ADV CONTROLLER CC 2
APM 51304685-150 APM ADV COMM CC 2
C200 51309241-125 Battery Extension Module 1
C200 51309288-225(TC-PRR021) PLANTSCAPE RM MODULE 2
C200 51309512-125(TC-FTEB01) FTE Bridge 0
C200 51309512-175 FTE Bridge Module, CC 1
C200 51309516-175 SIM Power Adapter Assembly, Coated 1
C200 51403427-125(TC-IOLI01 ) PM I/O link Module 2
C200 51404305-325 PCM Assembly, CE 1
C200 51404391-125 Serial I/F, User Configurable, 2CH, CE 1
C200 9904-TPR ControlNet T Tap right angle 4
C200 TC-CCN013 CNI Module, Single Media 1
C200 TC-CCR013 CNI Module, Redundant Media 2
C200 TC-FFPCX1 Power Supply Module, 1.3 A, RIOM-A 1
C200 TC-FPCXX2 120/240vac Pwr Supply 1
C200 TC-FPDXX2 24Vvdc Pwr Supply 0
C200 TC-FXX102 10 Slot Chassis, 13 Amp 2
C200 TC-FXX132 13 Slot Chassis, 13 Amp 2
C200 TC-IAH061 Analog Input 6pt Module, CIOM-A 1
C200 TC-IAH161 AI 16 Module (single or 8 diff.), CIOM-A 0
C200 TC-IDD321 DC Input Module 24vdc 32pt, CIOM-A 1
C200 TC-IDJ161 DC Input Module 24vdc 16pt (isoltd.), CIOM-A 1
C200 TC-IDW161 AC Input 220vac 16pt, CIOM-A, Coated 2
C200 TC-IXL061 Thermocouple Input Module 6pt, CIOM-A 1
C200 TC-IXR061 RTD Input Module 6pt, CIOM-A 1
C200 TC-OAH061 Analog Ouput 6pt Mod (4-20MA) CIOM-A 1
C200 TC-OAV061 Analog Output Module 6 pt (10V), CIOM-A 3
C200 TC-OAV081 AO Module 8pt (4-20ma & 10V), CIOM-A 1
C200 TC-ODD321 DC Output Module 24vdc 32pt ,CIOM-A 3
C200 TC-ODJ161 DC Output Module 24vdc 16pt, CIOM-A 1
C200 TC-PCIC02 ControlNet Interface Module, PCI bus 2
C200 TC-TBCH Field Wiring Connector 36 pos 1
C200 TC-TBNH Field Wiring Connector 20 pos 1
CABLE 51195153-002 Drop Cable Set, 2M RG6 1
CABLE 51195199-002 Cable Set, UCN Trunk RG-11, 2.5M 1
CABLE 51201420-005 Cable, FTA I/O Phone/Phone, 5M, non-CE 8
CABLE 51201420-010 Cable, FTA I/O Phone/Phone, 10M, non-EC 6
CABLE 51202306-915 Cable, I/O LIM Protection, 1.5M 1
CABLE 51304465-500 Cable, Twisted Pair w/Shield, 300cm 1
CABLE 51308112-003 Cable Set, LCN Coax, 3M 2
CABLE 51308112-008 Cable Set, LCN Coax, 8M 2
CABLE 80366198-100 Cable, Bridge 1M 1
FAN 51303940-150 Fan Assy w/Alarm, 115V, CC 3
FAN 51303940-250 Fan Assy w/Alarm, 230V, CC 2
FSC 10001/R/1 Vertical bus driver(VBD) 1
FSC 10005/1/1 watchdog(WD) module incl.10005/0/3 WD-Hbus pcb 1
FSC 10020/1/2 Quad processor module(QPM) 2
FSC 10024/I/F Enhanced communication module 1
FSC 10101/2/1 Fail-safe digital input module(24Vdc,16 channels) 1
FSC 10201/2/1 Fail-safe digital output module(8 channels) 1
FSC 10205/2/1 Fail-safe analog output module( 2 channels) 2
FSC 10300/1/1 24Vdc to 5 Vdc/12A converter 1
FSC 10302/2/1 watchdog Repeater(WDR) 1
FSC 10313/1/1 5VDC&WARCHDAG DISTRIBUTION MODULE 1
FTA 51204160-175 FTA, D/I 24VDC, Comp Term, CC, CE 3
FTA 51204166-175 HD FTA, D/O Relay, Comp Term, CC, CE 4
FTA 51204172-175 HD FTA, A/O w/Standby, Comp Term, CC,CE 3
FTA 51303932-476 FTA, Serial I/F, Modbus RS-232, CC 2
FTA 51304337-150 FTA,Redudant HLAI Comp Term,CC 2
FTA 51304338-100 Module, A/O Redundancy 2
FTA 51304437-150 FTA, LLAI 5
FTA 51304441-175 FTA, 24VDC D/I, Comp Term, CC 4
FTA 51304453-150 FTA, HLAI/STI, Comp Term, CC 2
FTA 51304650-150 FTA, 3/30VDC D/O, Comp Term, CC 2
FTA 51305890-175 FTA, LLMUX TC, Solid State, CC, CE 3
FTA 51305907-175 FTA, LLMUX2, RTD, CE, CC 4
FTA 51309148-125 FTA, 120V D/O Relay, Comp Term, CE 2
FTA 51309150-175 FTA,24OV D/O Relay, Comp Term,CC,CE 3
FTA 51309204-175 FTA, LLAI Mux/SDI/SI Pwr Adapter, CC 2
FTA 80366177-250 HD FTA, A/O Redn, Comp Term, CC 2
FUSE 30754661-011 Fuse, Subminiature, .25 Amp 10
FUSE 30754661-014 FUSE, 125V V/FA MICRO FUSE .500A 100 PCS / PACK 50
FUSE 30754661-021 Fuse, 2 Amp 40
FUSE 30754661-022 Fuse, 3 Amp 30
FUSE 51190584-150 Fuse, .5 Amp Slo-Blow 60
FUSE 83957061-002 Fuse, 0.5 Amp 35
FUSE 83957061-003 FUSE 1.0 AMP 30
FUSE 83957061-004 FUSE, 1.6 AMP 20
GUS 51153701-901 Mouse, USB, for Dell PE1800 Server 1
GUS 51305348-100 MAU Assy 1
GUS 51305378-100 IKBI2 PWA 2
