SIMCO ION 6432E静电消除器
品牌: SIMCO
所在地: 江苏 苏州市
最后更新: 2025-12-29 09:55
 ION6432离子风扇The Local Area Ionizing Blower Model 6432 and Model 6432e control static discharge in assembly, inspection, packaging areas, and in-tool wherver static build-up can cause contamination, ESD, material-handling problems or microprocessor lock-up.
Features
· In-tool mounting stand
· Benchtop mounting stand
· Input voltage: 24 VDC (±10%), 6 watts max. or 24 VAC (±10%), 50-60 Hz, 6 watts max.
Mounting: Small in-tool bracket/stand (1.8 x 5.1 in./45 x 129 mm); large
· benchtop stand (4.1 x 5.1 in./ 108 x 129 mm); both with 1/4” mounting hole and 10-32 truss head screws
便携式粒子计数器 微生物采样器 SIMCO ION XC静电消除器 SIMCO ION XC静电消除器P SIMCO ION FPD静电消除器 SIMCO ION CR2000静电消除器 SIMCO ION 6432E静电消除器 SIMCO ION CPM280 静电测试仪
