外观Appearance
透明液体
目测 Visual
黏度Viscosity,cps
1.600~2.400
Brookfield RVD-l+
硬化条件Curing condition,mj/cm2
3.000~4.000
硬度Hardness Shore oo
50
Durometr 00 type 参数ASTM D2240-03
抗拉强度Tensile strength,kg/cm2
0.4
收缩率Volume shrinkage,%
3.0
参照液体及固体比重计算
折射率ND Refractive index
25℃,60%RH
1.507
ATAGO Abbe Refractometer NAR-1T
吸水率Water absorption ratio
25℃/24hr,%
0.23
参照ASTM D570-95﹕
试片规格:圆形直径10mm×厚度2mm
伸长率Elongation,@25℃,%
9.2
GOTECH GT-TS-2000-M、GOTECH U55电脑系统
穿透率,Transmission,%
膜厚(0.1mm)
>99% >98%
500nm 450nm
JASCO Model V-530
雾度Haze,%
<0.2
高温高湿测试,85℃﹡85%RH 500hr
Pass
85℃﹡85%
Programmable Temperature﹠Humidity Chamber
冷热冲击-40℃~80℃×500 cycles
Pass
-40℃(0.5hr0)~ 80℃(0.5hr)
黄化指数Yellowing index
<0.7
参照ASTM G154
