《全自动硬质泡沫平切机、海绵切割机、泡绵机械》《全自动硬质泡沫平切机、海绵切割机、泡绵机械》
ECMT-138 138B
Automatic Phenolic/Rigid Foam Cutting Machine
全自动再生绵平切机
主要用途:
本机主要用于酚醛泡沫硬质泡沫板的切片工作.
Main Usage:
This Machine is special used for Phenolic Foam & Rigid Foam Blocks Cutting.
东莞市艾立克机械制造有限公司
电话:13662885182
QQ:2772194047
SPECIFICATION:
ECMT-138B |
ECMT-138 |
Cutting Foam Size: : |
W1650mm*L2000mm |
W2150mm*L3000mm |
Cutting Foam Height:
H1200mm |
H1200mm |
Cutting Thickness:
5mm Up
Cutting Thickness:
5mm Up
Cutting Speed: : |
0~15m/min(Adjustable)
Cutting Speed:
Blade Length:
L6900mm*W30mm*T0.45 |
Blade Length:
L8500mm*W30mm*T0.45 |
Cutting Type:
Automatic+Press Roller+ Dust Clean System
Cutting Type:
Blade Tension System:
Choose Available
Choose Available
Machine N.W:
2000kg |
Machine N.W:
2200kg |
Total Motor Power:
9.74kw |
Total Motor Power:
11.74kw |
Floor Space:
L5800mm*W3700mm*H2400mm |
Floor Space:
L7800mm*W4500mm*H2400mm |
