显示屏描述/Panel Description
显示屏尺寸/Panel Size
18.95Inch
显示屏类型/Panel Type
TFT LCD
屏幕比率/Display Ratio
16:10
AA区/Active Area
408.24X255.15mm
像素/Pixels
1440*900
点距/Pixel Pitch
0.2835mmX0.2835mm
亮度/White Luminance(TYP)
250cd/m²
颜色/Color
16.7M Colors
响应时间/Response Time
5ms
可视角度/Viewing Angle
Horizontal 150°,Vertical140°@CR≥10
触控描述/Touch Description
触控技术/Touch Technology
电磁感应
Electromagnetic Resonance
分辨率/Resolution
2048LPI
压感/Pressure Level
2048
报点率/Report Rate
200pps
精准度/Accuracy
±0.5mm(Center),±2mm(Edge)
倾斜角度/Tilt Angle
±45°from Vertical
感应高度/Sensor Height
5-15mm
接口/Interface
USB2.0
操作系统/Support OS
WinXP、Vista、Win7、Win8 and Mac OS
笔描述/Pen Description
类型/Type
无线无源笔/Wireless Pen without Battery
按键/Press Key
Upper Key(Mouse Right-Key Function)
Lower Key(User Defined)
笔尖/Pen Tip
Switch Freely
重量/Weight
20g
电源/Power Supply
电源类型/Power Supply Type
External DC Power Adapter
输入电压/Power
110V-220V
输出电压电流
12V/3A
功耗
30W
接口/Interface
电源接口/DC Jack
DC Jack*1
触控接口/Touch
USB*1
输入接口/Video Input
VGA IN*1,DVI*1,HDMI*1
操作控制/Operation Control
OSD
Chinese/English,9 languages
按键/Keys
Power On/Off、Up/Down、Menu、Auto
其他/Others
外形尺寸/Dimension
452(L)*320(W)*30(H)mm
净重/Net Weight
4KG
毛重/Gross Weight
5KG
工作温度/Working Temperature
0~50℃
工作湿度/Working Humidity
20~90%
储存温度/Storage Temperature
-20~60℃
储存湿度/Storage Humidity
10~90%
