显示屏描述/Panel Description
显示屏尺寸/Panel Size
10.1Inch
显示屏类型/Panel Type
TFT LCD
屏幕比率/Display Ratio
16:10
AA区/Active Area
216.96 (W)X135.6 (H) mm
像素/Pixels
1280*3(RGB)*800
点距/Pixel Pitch
0.0565mmX0.1695mm
亮度/White Luminance(TYP)
200cd/m²
颜色/Color
16.7M Colors
响应时间/Response Time
8ms
对比度/Contrast Ratio
800:1
可视角度/Viewing Angle
85/85/85/85(上/下/左/右)@CR≥10
触控描述/Touch Description
触控技术/Touch Technology
电磁感应
Electromagnetic Resonance
分辨率/Resolution
2048LPI
压感/Pressure Level
1024
报点率/Report Rate
200pps
精准度/Accuracy
±0.5mm(Center),±1mm(Edge)
倾斜角度/Tilt Angle
±45°from Vertical
感应高度/Sensor Height
5-15mm
接口/Interface
USB
操作系统/Support OS
WinXP、Vista、Win7、Win8、MAC
笔描述/Pen Description
类型/Type
无线无源笔/Wireless Pen without Battery
按键/Press Key
Upper Key(Mouse Right-Key Function)
笔尖/Pen Tip
Switch Freely
重量/Weight
10g
电源/Power Supply
电源类型/Power Supply Type
USB 5V
功耗
5W
接口/Interface
输入接口/Video Input
USB 2.0*1
其他/Others
外形尺寸/Dimension
290(L)*210(W)*19(H)mm
净重/Net Weight
0.65KG
毛重/Gross Weight
1.05KG
工作温度/Working Temperature
0~65℃
工作湿度/Working Humidity
20~80%
储存温度/Storage Temperature
-10~80℃
储存湿度/Storage Humidity
10~90%
