压铸模温机特点:
| 机型 | Model | 单位Unit | LDDC-18 | LDDC-36 | LDDC-48 | LDDC-18 |
| 温控范围 | Controlrange | ℃ | 350℃ | |||
| 温控精度 | Temp.controlaccuracy | ℃ | ±1℃ | |||
| 电源 | Power | AC3∮380V 50HZ | ||||
| 传热媒体 | Heattransfermedium | 导热油HEAT TRANSFER FLUID | ||||
| 冷却方式 | Coolingmethod | 间接冷却(INDIRECT COOLING) | ||||
| 加热能量 | Heatingcapacity | KW | 9+9 | 12*3 | 12*4 | 18+18 |
| 泵浦马力 | Pumppower | HP | 1 | 2 | 3 | 1+1 |
| 最大泵浦流量 | Max.Pumpfolw | L/MIN | 30 | 60 | 100 | 30 |
| 最大泵浦压力 | Max.Pump pressure | KG/CM2 | 5 | 5 | 9 | 5 |
| 最大电力消耗 | Powersupply | KW | 19 | 38 | 52 | 38 |
| 储油量 | Expansion tank capacity | LITER | 30 | 35 | 55 | 64 |
| 警报功能 | alertfunction | 缺相/缺水/超温/过载 | ||||
| 冷却水配管 | Coolingwaterpipe | INCH | 1/2 | 1/2 | 1/2 | 1/2 |
| 循环水配管 | Circulationwaterpipe | INCH | 3/4 | 3/4 | 1 | 3/4 |
| 外型尺寸 | LxWxH | MM | 1100*440 *1250 |
1100*440 *1250 |
1100*550 *1250 |
1100*550 *1250 |
| 重量 | Weight | KG | 120 | 150 | 180 | 220 |
