| Item 项目 | CONTENTS 内容 | Unit 单位 | |||||
| Outline Dimension 外形尺寸 | 以确认工程图为准 | mm | |||||
| Active Area(W*L)动作区 | 409.7*230 | mm | |||||
| View Area 可视区 | 408.7*229 | mm | |||||
| TP size (inch) 英寸尺寸 | 18.5 | inch | |||||
| Interface Type 接口种类 | IIC | - | |||||
| IC Type IC 型号 | ILI2302B | - | |||||
| Number of touchpoint 触点数量 | 5(10) | - | |||||
| Operation Temperature 工作温度 | TOPL = -10, TOPH =60 | ℃ | |||||
| Storage Temperature 储存温度 | TSTL = -40, TSTH =85 | ℃ | |||||
| Sensor thickness ITO 厚度 | 0.7 | mm | |||||
| Coverlens thickness 钢化玻璃厚度 | 1.1 | mm | |||||
| Lens Color 盖板顔色 | 黑色 | - | |||||
| Input force 输入外力 | <10 | g | |||||
| Surface hardness 表面硬度 | >7 | H | |||||
