Physical Properties
| 颜色 Color: | 透明無色 (colorless) |
| 黏度 VISCOSITY (CPS - 23°C): | 0.6 |
| 密度 Specific Gravity (25°C).: | 1.52 |
| 沸點 Boiling point(°C): | 61 |
| 保存條件 STORAGE: | 將容器確實鎖緊並儲藏在25º以下(storage under 25º ) |
| 閃點 FLASH POINT(°C): | 不適用 |
SUBSTRATE AND PRIMER
| 底材 SUBSTRATE: | Glass |
| 底材前處理 SUBSTRATE TREATMENT: | Dipping in Etching solution or plasma treatment until the water contact angle<10° before coating. |
APPLICATION
| 塗裝方法 APPLICATION METHOD: | 可使用旋轉塗布、浸泡、噴塗等方法製作 | ||
| 噴塗參數 SPRAY PARAMETER: | |||
| For EC 2XX | Precision Spray Coater | ultra sonic Spray Coater | |
| Head Speed (mm / sec) | 400 - 1000 | 250 – 400 | |
| Width (mm), 50% overlap | 5- 25 | 18-30 | |
| Height (mm) | 20 - 40 | 20 - 40 | |
| Flow Rate (ml / min) | 10-20 | 8-18 | |
| Material Usage (g / m2) | 18-32 | 14-26 | |
| 旋轉塗布參數 SPIN COATING PARAMETER: |
| 藥液用量(g/cm2) | 0.007–0.012 | ||
| 轉速(rpm) | 1100 | ||
| 時間(sec) | 5-15 | ||
| 噴塗時建議溫度 TEMPERATURE AT APPLICATION(°C): |
22 – 31 | ||
| 噴塗時建議濕度 HUMIDITY AT APPLICATION(%): |
78 – 45 (噴塗氣溫越高時建議濕度越低) | ||
| 烘烤條件 CURE SCHEDULES | |||
| 烘烤温度 BAKE TEMPERATURE(°C): |
150 | ||
| 烘烤時間(烘箱式) BAKE TIME(MIN): |
30 | ||
| 烘烤時間(IR輸送帶式) BAKE TIME(MIN): |
在最高溫區維持至少30分鐘 | ||
PERFORMANCE: according to customer requirement依客户要求
ADDITIONAL INFORMATION
· Use with appropriate protective equipment使用過程中請佩戴防護用品· Refer to individual MSDS for each component for specific safety information請參考物質安全資料表中每
一成分之安全規範資料
· Spray Booth Envoronment (噴塗時環境):22º - 31ºC, 45% < R.H < 78%
· Baking temperature is substrate temperature and Data Paq should be used to ensure temperature
compliance.
烘烤溫度是指底材達到的溫度,建議使用爐溫儀確保溫度準確
Product Code: EC201, EC202, EC203
| Revision # | Date of Revision | Reason for Revision |
| 1 | ||
| 製訂 | 覆核 | 批准 |
| Alex Hsieh |
