产品尺寸:87.5*91.5
产品特征:优质进口不锈钢冲压成型键盘
防水、防尘、防暴、防锈
按键字采用激光雕刻或化学腐蚀,防脱落
应用领域: 自助售票机、自助售货机、自助加油机、自助信息亭、电信查询机、圈存机、
自助多媒体机、数控机床、仪器仪表、安防门禁等
执行标准:符合标准:ISO/IEC 9995、GB/T 14081
产品性能:输入键盘:10个数字键,6个功能键
键扩充性:外接2片4键功能键
通信接口:标准PS/2或USB
按键寿命:超过2,000,000次
按键行程:不小于0.45mm
按键压力:2-3N(牛)
环境适应性:防护级别:IP65
工作温度:0℃~+40℃ 相对湿度:30%~90%RH
存储温度:-25℃~+55℃ 相对湿度:20%~95%RH(不结露)
大气压力:60~106Kpa
Type:D-8203
Basic introduction
System requirement:WIN2000、WINXP
Keypad made of high quality stainless steel
Dustproof,waterproof,shake-proof,pickproof,drill-proof,bombproof
CE,FCC and ROHS certificated
Applications
ATM,CDM,Self-service terminal,Payment Center, control,medicaldevice
Interface
Prepared external function bar
PS/2 or USB port
4*4 key (10 numeric keys,6 function keys)
Mechanism Characteristics
Key lifespan:>2,000,000,00
Key press force:3~5N
Key travel:>0.45mm
Environment adaptation
Protection level:IP65(static)/IP54(dynamic)
Operation temperature
Economical Grade:-20~+65 RH:30%~90%
Storage temperature(Recommended):-25~+75RH:20%~95%(No condensate)
Air pressure:60~106Kpa
All surface can be customed according to customer's demand
