| Model |
1939L |
| Display |
19.0" diagonal |
| Aspect Ratio |
5:4, Active matrix TFT LCD |
| Useful Screen Area |
Horizontal: 14.8" (376 mm) |
| Vertical: 11.9 " (301 mm) |
| Native (Optimal) Resolution |
1280 x 1024 |
| Other Supported Resolutions |
1280 x 1024 60, 75 Hz |
| 1280 x 960 60 Hz |
| 1152 x 864 75 Hz |
| 1024 x 768 60, 70, 75 Hz |
| 1024 x 768 65 Hz (Sun) |
| 832 x 624 75 Hz (Mac) |
| 800 x 600 56, 60, 72, 75 Hz |
| 720 x 400 70 Hz |
| 720 x 350 70 Hz |
| 640 x 480 60, 72, 75 Hz |
| 640 x 480 66 Hz (Mac) |
| Colors |
16.7 million |
| Brightness |
LCD panel: 250 nits |
| (Typical) |
AccuTouch: 200 nits |
Acoustic Pulse Recognition: 225 nits |
IntelliTouch: 225 nits |
| Response Time - Total (Typical) |
25 msec |
| Viewing Angle |
Horizontal: 178° total |
| (Typical) |
Vertical: 178° total |
| Contrast Ratio (Typical) |
1300:01:00 |
Controls (side): menu, up, down, select, power |
| Settings: contrast, brightness, H/V position, RGB (color temp), clock, phase, recall |
| Languages: English, German, Spanish, Japanese, French |
| Lockouts: power, user controls |
| Input Video Format |
Analog VGA |
| Input Video Signal Connector |
Mini D-Sub 15-Pin VGA type |
Horizontal: 31.5-80 kHz |
| Vertical: 56.3-75 Hz |
| Power Supply |
External DC - optional power brick |
| Input power connector specification (Monitor) |
| Type: DC Barrel Jack |
| Barrel inner diameter: 6.4mm (+/- 0.3mm) |
| Pin outer diameter: 2.0mm (+0.0 -0.1mm) |
| Barrel depth: 8.8mm (+/- 0.3mm) |
| Input voltage range: +12VDC ±5% |
| Input power connector specification (Power brick) |
| Type: IEC 60320 C14 |
| Adaper input voltage range: 100-240VAC, 50/60Hz |
| Power Consumption (Typical) |
Monitor only:38W Monitor and power brick:43W |
| Monitor Dimensions (with Stand) |
Width:16.3" (415 mm) |
| Height: 13.5 " (343 mm) |
| Depth: 2.0 " (51 mm) |
| Dimensions vary with stand position and options selected |
| Shipping Box Dimensions |
20.28" (515mm) x 17.72 " (450 mm) x 6.89 " (175 mm) |
| Temperature |
Operating: 0°C to 40°C (32°F to 104°F) |
| Storage: -20°C to 60°C (-4°F to 140°F) |
| Humidity (non-condensing) |
Operating: 20%-80% |
| Storage: 10%-90% |
Open-frame |
| Enclosure Color |
steel/black |
| MTBF |
50,000 hours demonstrated |
| Stand Options |
Removable |
75 mm or 100 mm VESA mount |
| Rear mount or with included standard mounting brackets |
| Front mount with optional bezel (see Accessories tab for details) |
| Rack mount with optional bracket (see Accessories tab for details) |
Touchscreen sealed to bezel |
| Touchscreen sealed to LCD |
