| 机型 | 1515L |
| 外壳/边框颜色 | Dark gray and beige |
| 显示类别 | 活动矩阵TFTLCD |
| 显示器尺寸 | Size: 15.0" diagonal |
| Aspect ratio: 4 x 3 | |
| 显示区域 | Horizontal: 12.0" (304 mm) |
| Vertical: 9.0" (228 mm) | |
| 显示器尺寸 | Width: 13.8" (350 mm) |
| Height (inc. base): 12.2" (310 mm) | |
| Depth (inc. base): 6.9" (175 mm) | |
| 尺寸图编号 | MS600556 Rev A |
| 最佳(真实)分辨率 | 1024 x 768 |
| 其它支持分辨率 | 1024 x 768 at 60, 65 Hz (Sun), 70 or 75 Hz |
| 832 x 624 at 75 Hz (Mac) | |
| 800 x 600 at 56, 60, 72 or 75 Hz | |
| 720 x 400 at 70 Hz | |
| 720 x 350 at 70 Hz | |
| 640 x 480 at 60, 66 Hz (Mac), 72 or 75 Hz | |
| 颜色 | 16.2 million |
| 亮度-LCD面板 | LCD panel: 250 cd/m2 (typical) |
| 亮度-带触摸屏的LCD面板 | with AccuTouch: 200 cd/m2 (typical) |
| with Acoustic Pulse Recognition: 230 cd/m2 (typical) | |
| with IntelliTouch: 230 cd/m2 (typical) | |
| 响应时间 | 14.5 msec (typical) |
| 视解(从中间) | Horizontal (left/right): ±70° or 140° total |
| Vertical (up/down): 60 °/55° or 115° total | |
| 对比度(标准值) | 500:1 (typical) |
| 输入视频模式 | RGB模拟 |
| 输入同步模式 | 分离式H/V同步、合成同步、绿同步 |
| 输入视频信号连接器 | MiniD-Sub 15针VGA型连接器 |
| 输入频率 | Horizontal: 31.5-60.2 kHz |
| Vertical: 56.3-75 Hz | |
| 电源 | Type: Internal, with jack to accept power from optional external brick |
| Monitor input voltage: 100-240 VAC, 50/60 Hz | |
| Optional input voltage: +12VDC ±5% | |
| 附加功能 | USB 磁卡读卡器 |
| 功耗 | 最大30W |
| 温度 | 工作温度0℃-40℃;储藏温度-20℃-60℃ |
| 保修 | 三年保修 |
