| 机型 | 1915L |
| 外壳/边框颜色 | Dark gray |
| 显示类别 | 活动矩阵TFTLCD |
| 液晶屏尺寸 | Size: 19.0" diagonal |
| Type: Active matrix TFT LCD | |
| Aspect ratio: 5 x 4 | |
| 显示区域 | Horizontal: 14.82" (376.32 mm) |
| Vertical: 11.85" (301.06 mm) | |
| 显示器尺寸 | Width: 16.9" (429 mm) |
| Height: 14.92" (379 mm) | |
| Depth: 8.15" (207 mm) | |
| 尺寸图编号 | MS600183 Rev A |
| 最佳(真实)分辨率 | 1280 x 1024 |
| 其它支持分辨率 | 1280 x 1024 at 60 or 75 Hz |
| 1152 x 864 at 75 Hz | |
| 1024 x 768 at 60, 65, 70 or 75 Hz | |
| 832 x 624 at 75 Hz (Mac) | |
| 800 x 600 at 56, 60, 72 or 75 Hz | |
| 720 x 400 at 70 Hz | |
| 720 x 350 at 70 Hz | |
| 640 x 480 at 60, 66, 72 or 75 Hz | |
| 颜色 | 16.7 million with dithering |
| 亮度-LCD面板 | LCD panel: 300 cd/m2 (typical) |
| 亮度-带触摸屏的LCD面板 | with AccuTouch: 240 cd/m2 (typical) |
| with IntelliTouch: 270 cd/m2 (typical) | |
| 响应时间 | 5 msec (typical) |
| 视角(从中间) | Horizontal (left/right): ±80° or 160° total |
| Vertical (up/down): ±80° or 160° total | |
| 对比度(标准值) | 800:1 (typical) |
| 输入视频模式 | Analog (no proprietary video card needed) |
| 输入同步模式 | Separate horizontal and vertical sync, composite sync and sync-on-green |
| 输入视频信号连接器 | Mini D-Sub 15-Pin VGA type |
| 输入频率 | Horizontal: 31.5-80 kHz |
| Vertical: 56.3-75 Hz | |
| 电源 | Type: Internal, with jack to accept power from optional external brick |
| AC input (line) voltage: 85-265 VAC, 47–63 Hz | |
| DC input (line) voltage: 12.0 VDC ±0.75V | |
| 附加功能 | 无 |
| 功耗 | 50 W max. |
| 温度 | 工作温度0℃-40℃;储藏温度-20℃-60℃ |
| 保修 | Monitor: 3 years |
| Backlight lamp life: typical 40,000 hours to half brightness | |
| 机构认证 | North America/Worldwide: UL, cUL, S, MPR II, FCC, CE, VCCI, IC, C-Tick |
| Asia: UL, cUL, S, MPR II, FCC, CE, VCCI, IC, C-Tick, MIC, CCC, BSMI, China RoHS | |
| 用户控制 | OSD buttons: menu, up, down, select, power |
| OSD: contrast, brightness, H/V position, RGB (color temp), clock, phase, recall, language (English, German, Spanish, Japanese, French) | |
| OSD disable/enable: power, OSD menu | |
| 安装选择 | Threaded-through mounting holes, under base |
| Removable base, 100 mm VESA mount |
