●技术参数: ●Technical parameters:
机器型号:CH–102 Machine model: CH - 102
机器尺寸:L450×W350×H620mm Machine size: L450 x W350 x H620mm
UV灯参数:1KW×230mm×1支 UV lamp: 1KW * 230mm * 1
UV灯种类:紫外线高压汞灯 UV lamp types: ultraviolet high pressure mercury
灯管强度:100% lampLamp intensity: 100%
UV灯功率密度:100W/cm The UV lamp power density: 100W/cm
冷却方式:强制风冷 Cooling: forced air.
自动延时关机:无 Automatic delay shutdown: no
外接电源:220V External power supply: 220V
温度参考:动态温度低于65℃ The temperature reference: dynamic
temperature below 65 ℃
●适应范围:紫外线UV胶固化,油墨或者漆料固化
●Applicable scope: ultraviolet UV curing, ink or paint curing
●可添加:故障报警,其它未说明事项可按客户需求定做
●add: fault alarm, other unspecified matters can be customized according to customer demand
