●技术参数: ● Technical parameters:
机器尺寸:L1250×W450×H1250mm Machine size: L1250 x W450 x H1250mm
UV灯参数:2KW×360mm×1支 UV lamp: 2KW * 400mm * 1
UV灯种类:紫外线高压汞灯 UV lamp types: ultraviolet high pressure mercury lamp
灯管强度:100% Lamp intensity: 100%
UV灯功率密度:100W/cm The UV lamp power density: 100W/cm
UV灯可调高度:100—170mm(可调) UV lamp with adjustable height: 100 - 170mm ( adjustable)
输送带材质:特氟龙或不锈钢 Conveyor belt material: Teflon or stainless steel
输送速度:0.1-10m/min Transmission speed: 0.1-10m/min
输送带宽度:300mm Belt width: 300mm
冷却方式:强制风冷 Cooling: forced air.
自动延时关机:有 Automatic delay shutdown:Yes
外接电源:220V External power supply: 220V
●适应范围:紫外线UV胶固化,油墨或者漆料固化
●Applicable scope: ultraviolet UV curing, ink or paint curin
