销售部电话: +86-510-81880058
业务QQ: 1956937953 邮箱:benny.qian@solutx.com
手机: +86-15151775766 网站:www.solutx.com
产品介绍:
RF Cable一般称为射频同轴连接线或者精密同轴电缆,是高頻天线的一种,主要用于传输或接收射频信号。RF即为Radio Frequence ,CABLE即电线电缆,是用以传输电(磁)能、信息、和实现电磁能转换的线材产品。
同轴电缆是一种电线及信号传输线,一般是由四层物料造成:最内里是一条导电铜线,线的外面有一层塑胶(作绝缘体、电介质之用)围拢,绝缘体外面又有一层薄的网状导电体(一般为铜或合金),然后导电体外面是最外层的绝缘物料作为外皮。根据尺寸来分同轴电缆则有不同标准规格,从1/8英寸到9英寸直径不等。同轴电缆具有装配密度更大、信号保真度更高、耐弯曲度更高,以及电容和传播延迟更低等特点。 此类线缆的尺寸和配置(最小可达 50 AWG)十分丰富,并可设计符合不同规格。
GigaLane采用了材料科学的最新成果,满足各种苛刻的电子、机械和环境要求。我们的电缆是为最高要求的应用设计的,以满足客户最严格的性能要求。
产品的应用领域及相关产品介绍如下:
RRH Connection -RRH(Remote Radio Head)
• Miniaturized & Cost Reduction
• Cable-Less Solution (Board to Board solution
Mass Product Test-RF Test Equipment(Vector Network Analyzer)
• High Durability & Flexibility
• Longer cable replacement cycle of VNA
• High performance cable is demanding
Military- High Reliability Cable
• Military BTS, RU
• High Frequency
• Low Loss cable
Laboratory Test- Precision RF Test Cable
• Evaluated performance at earlier stage of development
Microwave
• Higher M/W
• 26.5 GHz ~
• Low loss cable is demanding
GIGALANE的优势:
Up to 25% lower cost than any competitors in China for higher performance cable & connectors.
Proven Technology & Quality by Samsung (Leading Manufacturer of Telecommunication device)
业内产品比较:
Gore
High Frequency and Spec Cable Supplied
Lower Frequency and Low Loss Cable Supplied
The price is much higher than Gigalane for same products.
Huber + Suhner
Reliable reputation
No Raw Cable supplied. Only Assembled Cables.
如有需要,请与我们联系。谢谢!
