详细资料请参考本公司网站产品信息内容。欢迎广大客户来电咨询。
销售部电话: +86-510-81880058
业务QQ: 1484298574 邮箱:wendy.dong@solutx.com
手机: +86-13306189603 网站:www.solutx.com
部分产品信息如下:
主要型号:
ION-BAR MB-AW Series:
ION BAR MB-GW/PW Series:
ION BAR MB-L Series:
ION-BLOWER SF-40A:
ION BLOWER MF-90 Series:
ION BLOWER MF-A90 Series:
ION NOZZLE ZM-G11, ZM-G12:
ION GUN ZM-GIG:
ION CONTROLLER ZM-G1C:
ELECTROSTATIC FIELDMETER SS-M:
规格如下:
产品规格:
类别与规格:
1.主体尺寸(Dimensions):35mm (D) ×69.4mm (H), Customizer Specified Length
2.输入电压(Input Voltage): +24VDC
3.输出频率(Output Frequency): 0.1Hz-60Hz
4.离子生成方式(Ion Emission): Pulsed AC
5.放电针(Emitter Pins): Tungsten
6.放电针更换(Emitter Replacement): Replaceable
7.离子平衡(Ion Balance): <±30V
8.设定距离(Coverage Distance): 100mm-2000mm
9 供给气体(Supply Air): CDA (Clean Dry Air), N2
10.气体压力(Air Pressure): Typically 3kgf/cm2
11.臭氧发生量(Ozone Output): Less than 0.005ppm
12.主体材料(Body Material): ABS
13.显示功能(Indicators): Power LED (G), Ion (G), HV Alarm(Y/R)
14.使用温度(Ambient Temp): 0℃~50℃
15.使用湿度(Ambient Humidity): 35~65% RH (No condensation)
产品规格:
类别与规格:
3.输出频率(Output Frequency): 28kHz
4.离子生成方式(Ion Emission): Pizeo High Frequency AC
10.气体压力(Air Pressure): Typically 3kgf/cm2 (Max 5kgf/ cm2)
产品规格:
类别与规格:
1.主体尺寸(Dimensions):65H ×54.5W×250L~1,500L(mm)
2.输入电压(Input Voltage): +24VDC±10%
3.输出频率(Output Frequency): 0.1Hz~10Hz
5.放电针(Emitter Pins): Titanium
13.显示功能(Indicators): Power LED (G), HV Alarm(G/R)
ION-BLOWER SF-40A:
产品规格:
类别与规格:
1.主体尺寸(Dimensions): 46W×68.5H ×36mm(D)
2.输入电流(Input Current): DC24V,0.15A
3.离子生成方式(Ion Emission):High frequency AC
4.放电针(Emitter Pins): Titanium
5.离子平衡(Ion Balance): <±10V
6.消除静电时间(Decay Time):1.5sec at 15cm
7.风量(Air Flow): 0.27m2/min (Max)
8.臭氧发生量(Ozone Output): Less than 0.05ppm
9.显示功能(Displays): High Voltage LED (G/R), Fan LED(G/R), G/R: Normal/ Abnormal
10.手动调节功能(Adjustable Controls): Fan Speed/Ion Balance (Manual Adjustment),
11.使用温度(Ambient Temp): 0℃~+50℃
12.使用湿度(Ambient Humidity): 35~65% RH (No condensation)
产品规格:
类别与规格(1-Fan, 2-Fan, 3-Fan,4-Fan, 5-Fan):
1.电源(Power): AC 100-22-V (60Hz) or DC 24V
2.输入电流(Input Current): DC24V, 0.15A
5.离子平衡(Ion Balance): <±10V typical
6.消除静电时间(Decay Time):Better than 2 seconds at 30cm
7.风量(Air Flow): Max. 1.75m2/min pre Fan
9.显示功能(Displays): High Voltage Alarm LED (G/R), Fan Alarm LED (G/R),
(G/R) Green: Normal, Red: Abnormal
12.重量(Weight): 按规格依次为:1kg, 1.9kg, 2.8kg, 3.7kg, 4.6kg
13.使用湿度(Ambient Humidity): 35~65% RH (No condensation)
产品规格:
2.输入电流(Input Current): 按规格其最大输入电流依次为:0.4A, 0.4A, 0.6A, 0.8A, 1.2A
3.离子生成方式(Ion Emission):Pulsed AC
5.离子平衡(Ion Balance): <±30V typical
12.重量(Weight):按规格依次为 1kg, 1.9kg, 2.8kg, 3.7kg, 4.6kg
产品规格:
类别与规格:
1.输入电压(Input Voltage): +24VDC
2.离子生成方式(Ion Emission): Pizeo HF-AC
3.工作频率(Output Frequency): 50 kHz
4.离子平衡(Ion Balance): <±15V
5.离子平衡调节(Ion Balance Adjustment): Auto
6.消除静电时间(Decay Time):1.0 seconds at 15cm (air 3kgf/ cm2)
7.显示功能(Indicators): HV LED (G/R)
8.放电针(Emitter Pins): Titanium
9.放电针更换(Emitter Replacement): Only Pin
10.气体压力(Air Pressure): Max 5kgf/cm2 (N2, CDA)
11.喷出力(Blow-off Force):128l/ cm2 (air 3kg/cm2)
12.气体输入管的外径(Air Purge Connection Tube): 6Φ
13.臭氧发生量(Ozone Output): Less than 0.05ppm at 100mm
14.重量(Weight): 70g(except bracket)
ION GUN ZM-GIG:
产品规格:
类别与规格:
14.重量(Weight): 155g (except bracket)
产品规格:
类别与规格:
1.输入电压(Input Voltage): AC100V~220V, 50~60Hz
2.输出电压(Output Voltage(Typical)): +24VDC
3.额定功率(Regularity Power): 12W
4.显示功能(Indicators):Power(G), RUN(G), H.V Alarm(R)
5.气体调节(Air Control): Typically lower than 5 kgf/ cm2 (Mix.7kgf/ cm2)
6. 气体输入管的外径(Air Purge Connection Tube):Intel 8Φ, Outlet 6Φ
7.使用温度(Ambient Temp): 0℃~50℃
8.使用湿度(Ambient Humidity): 35~65% RH (No condensation)
9.重量(Weight): 750g
产品规格:
类别与规格:
1. 主体尺寸(Dimensions):55.5mm (W) ×40.2mm (H) ×70.1mm (D)
3.耗电量(Power Consumption): 3W以下
4.传感器(Sensor): DIT Electrostatic Voltage Sensor
5.测定距离(Distance): 精密模式:25mm (±0.5)Fixed, 扩张模式:50mm~100mm(±0.5)
6.测定范围(Range): 精密模式:±2kV(±5%), 扩张模式:±20Kv (±10%)
7.分辨率(Resolution): 精密模式:1V, 扩张模式:10V
8.线性度(Linearity): ±5%F.S
9.响应时间(Response Time): 100ms~5sec selectable
10.模拟输出(Analog Output):1~5V
11.通讯(Communication): RS-485
12.显示功能(Indicators): Power LED (G), Ion (G), +/- Polarity (Y/O)
13.使用温度(Ambient Temp): 0℃~50℃
14.使用湿度(Ambient Humidity): 35~85% RH
