UV Screen-Printing Resist
LM-600 LP-400 BL8系列為一種UV曝光鹼液去膜型之絕緣耐酸光阻劑,為一性能優異的網印印刷油墨,具有高度之解像力。此光阻劑具有快速硬化及良好的印刷性,乾燥後其表面堅硬,適用於光電精密點線路之製造。
LM-600 LP-400 BL8 series is a screen printing UV etching resist designed for flat monitor fabrication. It has sharp pattern, high resolution and excellent properties with fine dot and line defined. Also has fast curing speed, excellent printing properties and forming a tough protective film after curing.
技術資料Technical Data
項目
LM-600 LP-400 BL8
顏色 Color
藍色blue
黏度(25℃)
200 ± 30 PS (VT-04, #2針, #2 Spindle)
曝光條件UV Exposure
800~1500 mJ/cm2
鉛筆硬化(JIS K5400)
Film hardness by pencil lead
≧1H
抗酸蝕刻
Acid etching resistance
良好Excellent
去墨條件
Condition of remove coating film by alkali
10-40 秒在25-50 oC的1.5~3% NaOH水溶液
10-40 seconds at 25-50 oC for 1.5~3% NaOH aqueous solution
貯存安定性 Shelf life at 15-30 ℃ under dark packing
6個月 6 month
以上各項數據僅供參考
The above information is for reference only.
