光硬化無色油墨 LM-600 DM10EDB
UV-CURING COLORLESS INK LM-600 DM10EDB
LM-600 DM10EDB是UV硬化顯示器保護膜油墨,具備高度底材黏著性,提供良好的絕緣、透明以及表面硬化。
LM-600 DM10EDB is a UV cured ink designed for using screen printing on the glass or PET substrate. It has excellent printing properties and forming a tough protective film after UV curing. The cured film has excellent in adhesion, heat resistance and excellent electrical properties.
技術資料Technical Data
項目
Items
LM-600 DM10EDB
顏色
Color
無色Colorless
黏度(25℃)
Viscosity(25℃)
130 ± 20 PS (VT-04, #2)
塗佈方式
Coating
150~420網目網印
(Screen Printing, 150~420 Screen mesh)
硬化條件
Curing Condition
800~1500mJ/cm2
塗膜硬度(鉛筆硬度)
Film hardness
3H
塗膜百格切割附著
Cross Cut
100/100
貯存安定性
Shelf life at 15-30℃ under dark packing
6 month
以上各項數據僅供參考
The above information is for reference only.
