适用范围:
适合于检测灯等有复杂构造的产品,检测高密度的塑料产品,如隐形眼镜等,检测光学晶体,如氟化钙(萤石)等。
型号 |
PTC-403 |
尺寸 |
W280×D375×H410mm |
重量 |
10Kg |
测样有效长度 |
W200×D200mm |
测量空间高度 |
300mm |
光源 |
LED光源 寿命4万小时 |
电源 |
交流220V |
附件 |
应力方向确认棒 清洁液1瓶 波长检板 2个 |
净重 |
10KG |
<Application>
・Existence or nonexistence, direction and measurement of strain for glass product
・Existence or nonexistence of strain for plastic product
* Operator have to insert the wave plates by his hand when he changes the inspection method.
Specification |
PTC-403 |
Size |
W280×D375×H410mm |
Weight |
10kg |
Inspection method |
Crossed Nicols Method Sensitive Color Method |
View area |
W200×D200mm |
Light source |
White LED 3,000K |
Power source |
AC100~240V 50/60Hz |
