联 系 人:周
联系方式:025-84584473/6/9
公司邮箱:
产品简介:
4U 便携式CompactPCI/PXI系统平台
C443-8BYV-P2XX
CONTEC-康泰克C443-8BYV-P2XX机箱/底板
C443-8BYV-P2XX
Standards: CompactPCI® 2.0 R3.0
Form Factor: For 3U CompactPCI® cards without rear I/O
Enclosure: Coated metal plate outer covering with aluminum
Cooling System: Bottom-access removable fans for intake:
12V DC brush-less, ball bearings
Two fans with 67.02 CFM/fan
Rated speed for each fan: 4500 RPM
Rated power for each fan: 6 W
Power Supply Power backplane
Supports single in-rack 3U cPCI 8HP power modules
PICMG® 2.11 47-pin power interface
DC input models available for OEM programs
Backplane cBP-3206: 2-8slot 32-bit 3U cPCI/PXI Backplane
Chassis Partition Five slots for peripheral cards
Dimensions 221.4 x 237 x 177 (mm, W x D x H, w/o wall mount kit or stand feet)
253.1 x 237 x 177 (mm, W x D x H, with wall mount kit or stand feet)
Weight 4.5 kg/9.9 lbs (without SBC, PSU, with backplane)
Operating Temp. 0°C to 60°C
Storage Temp. -20°C to 80°C
Humidity 5% to 95%, non-condensed
Shock 15 G peak-to-peak, 11 ms duration, non-operation
Vibration Non-operation: 1.88 Grms, 5-500 Hz, each axis
Operation: 0.5Grms, 5-500 Hz, each axis, tested with 2.5" HDD
