YL-6613 电磁式振动试验台 Electromagnetic Vibration Tester
用途:
电动式振动试验系列广泛适用于国防、航天、通讯、电子、汽车、家电等行业。该类型设备用于发现早期故障,模拟实际工况考核结构强度试验,产品应用范围广泛、 适用面宽、试验效果显著、可靠。
Electromagnetic Vibration Tester is widely used in national defence, aviation, aerospace,communications, electronics, motor vehicles, electrical and other industries. The type of equipment used to detect early failure, simulate actual working conditions and the structural strength assessment test, a wide range of product applications, wide application, test results are obvious and reliable.
产品特点:
采用最先进可程式技术,可以设定程序,多段扫频可同时工作的功能
产品特点:
进口频率控制器,数字化控制与显示频率,PID调节功能,使设备工作更为稳定、可靠
控制参数实时同步显示,无须人工干预。(各种控制条件,可于运转中监视之)
精密型设计制造,一体式垂直台体,外观精美,超静音工作
四点同步激振,台面振动均匀
无级调整振幅,定频及扫频操作功能适应不同行业多种试验要求
增加抗干扰电路,解决因强电磁场对控制电路干扰
增加工作时间设定器,使测试产品达到更好测试要求
Feature:
♦Using the most advanced programmable technology, setting the program,working simultaneously with multi-segment sweep frrquency.
♦With the functions of single point, segment, multi-segment time setting and countdown
♦Import frequency controller, digital control and frequency display, PID adjustment function, making the equipment work more stable and reliable
♦Display real-time synchronization control parameters, without human intervention. (Various control conditions, can monitor the operation)
♦Machine base is made of anti-vibration devices, easy-installation,smooth operation, without having to install the screw feet
♦Embedded procedures and amplitude modulation is easy-prediction.
♦Precise design and manufacturing , small size, ultra-quiet working circumstance
♦Stepless adjustment of the amplitude, fixed frequency and sweep operation functions to adapt to a variety of test requirements of different industries
♦Increase in anti-interference circuit, address the strong electromagnetic field interference on the control circuit.
♦ anti-jamming circuit design , solve strong electromagnetic field to control circuit of interference
♦ Set the device to work more hours, to make the test product achieve better requirements.
规格Specification:
型 号Model NO.
YL-6613-V3
YL-6613-70A
功能
正弦波、调频、扫频、时间控制
Sine wave,Frequency modulation,Sweep frequency,Time control.
工作台面尺寸Work Table Size
450×450×46mm(L*H*W)
550×550×46mm(L*H*W)
工作台体尺寸
Dimension Of Table(mm)
450×450×450mm(L*H*W)
550×550×350mm(L*H*W)
控制箱尺寸Control Box Size
450×320×740mm(L*H*W)
450×330×750mm(L*H*W)
最大试验负载MaximumTest Load
40kg
60 kg
振动方向Vibration Direction
垂直Vertical
振动波形Vibration Waveform
正弦波Sine wave
调频功能
Frenquency Modulation
在频率范围內任一频率必须在(最大加速度<20g最大振幅<5mm)
Any frenquency must be within frenquency range. (peak acceleration<20g,Peak amplitude<5mm)
隔离磁场功能
nsulate Magnetic Field
镁合金材质的面板可完全隔离磁场
Magnesium alloy plate can insulate magnetic field totally
扫频功能
Sweep Frequency
(上频率/下频率/时间范围)可任意设定真正标准来回扫频(upper frequency/lower frequency/time range)
Can set freely real standard to back and forth sweep.
振幅(可调范围mmp-p)
Amplitude (adjustable rangemmp-p)
0 ~ 5mm
振动频率 Vibration Frequency
5~200HZ可设置
5~200HZ(may be set)
1~200HZ可设置
1~200HZ(may be set)
精密度Accuracy
频率可显示到0.01Hz,精密度0.1Hz
Frequency can display to 0.01Hz,Accuracy:0.1Hz
设时范围Time SettingRange
0.01S~99.99H
电源电压(V) Voltage(V)
AC220/50 ±5%
AC220/50 ±2%
振动机功率 Power
2.2 KW
