产品名称:四线RS232(COM)接口控制器 S4RG V1.08DA ETP-SAT4500G-G
控制器的详细参数
触摸屏分辨率: 2048x2048
4点定位 / 25点定位
支援鼠标右键
支援画线测试
多语系的操作窗口
支援多个监视器
具备视觉旋转度
触摸屏通讯接口 : RS232 或 USB 或 PS2
计算机通讯接口 : Pin Header
驱动程序包括: ( Windows Vista,Windows 98, 2000, NT4, Me, XP, XP Tablet Edition,
CE 2.12, CE 3.0, CE.net, Linux, DOS & iMac)
电气参数
电源要求 : +5VDC ( Maximum 100mA, typical 70mA, 50mV peak to peak maximum ripple)
工作温度 : 0 to 50℃
贮存温度 : -40 to 80℃
湿度 : 95% at 60℃
通讯协定 : RS232 Model: 9600 bauds, None parity, 8 data bits, 1 stop bit
USB Model: USB 1.1 Low speed
PS/2 Model: PS/2 mouse
采样速度: RS232 Model: Max. 160 points/sec
USB Model: Max. 160 points/sec
PS/2 Model: Max. 140 points/sec
最大按压延迟时间: Max. 35 ms
出线顺序: X+, Y+, X-, Y-
电阻范围: 300 ~ 900 ohm ( pin to pin on the same layer )
英文版
It communicates with PC system directly though USB connector.
You can see how superior the design is in sensitivity, accuracy and friendly operation. The touch panel driver emulates mouse
left and right button function and supports operations systems,including Microsoft Windows Vista, Windows XP,2000,95/98 Windows Me,
NT4.0,CE2.12 & 3.0/ NET ,DOS
Circuit Board Dimension: 20mm x 68mm (0.79inches x 2.68inches)----(4-Wire)
Power Requirements:D.C.+5V (100mA typical,50mV peak to peak maximum ripple and noise)
Operating Temperature:0 to 50 ℃
Storage Temperature:-40 to 80 ℃
Relative Humidity:95% at 60 ℃
Interface:USB 1.1 Low Speed
Report rate:USB Model: Max. 160 points/sec
Response time:Max. 35 ms
Attached Cable:6' shielded cable with USB-A connector for
Regulatory Approvals:FCC-B , CE,Unaffected by EMI from other nearly CRTs
and other display devices
EMI:Unaffected by environmental EMI
Panel resistance:4 wire resistive model: 300 ~ 900 ohm
联系方式:13825015307 QQ:565004903 / 79759504
邮箱:hongyitouchpanel@163.com MSN: boyliuying@hotmail.com
通过中国触摸屏网金牌会员认证
