产品名称:5线RS232(COM)接口控制卡 S5RM V1.08D1 ETP-SAT-4500G-G
控制器的详细参数
触摸屏分辨率:2048x2048
4点定位 / 25点定位
支援鼠标右键
支援画线测试
多语系的操作窗口
支援多个监视器
具备视觉旋转度
触摸屏通讯接口 : RS232 或 USB 或 PS2
计算机通讯接口 : Pin Header
驱动程序包括: ( Windows Vista,Windows 98, 2000, NT4, Me, XP, XP Tablet Edition,
CE 2.12, CE 3.0, CE.net, Linux, DOS & iMac)
电气参数
电源要求 : +5VDC ( Maximum 100mA, typical 70mA, 50mV peak to peak maximum ripple)
工作温度 : 0 to 50℃
贮存温度 : -40 to 80℃
湿度 : 95% at 60℃
通讯协定 :RS232 Model: 9600 bauds, None parity, 8 data bits, 1 stop bit
USB Model: USB 1.1 Low speed
PS/2 Model: PS/2 mouse
采样速度:RS232 Model: Max. 160 points/sec
USB Model: Max. 160 points/sec
PS/2 Model: Max. 140 points/sec
最大按压延迟时间: Max. 35 ms
出线顺序: X+, Y+, X-, Y-
电阻范围: 300 ~ 900 ohm ( pin to pin on the same layer )
英文版
This touch panel controller provides the optimistic performance of your analog resistive touch panels for 4wire models.
It communicates with PC system directly though USB connector.
You can see how superior the design is in sensitivity, accuracy and friendly operation. The touch panel driver emulates
mouse left and right button function and supports operations systems, including Microsoft Windows Vista, Windows XP,2000,
95/98 Windows Me, NT4.0,CE2.12 & 3.0/ NET ,DOS
· Circuit Board Dimension:20mm x 68mm (0.79inches x 2.68inches)----(5-Wire)
· Power Requirements:D.C.+5V (100mA typical,50mV peak to peak maximum ripple and noise)
· Operating Temperature:0 to 50 ℃
· Storage Temperature:-40 to 80 ℃
· Relative Humidity:95% at 60 ℃
· Interface:USB 1.1 Low Speed
· Report rate:USB Model: Max. 160 points/sec
· Response time:Max. 35 ms
· Attached Cable:6' shielded cable with USB-A connector for
· Regulatory Approvals:FCC-B , CE,Unaffected by EMI from other nearly CRTs and other display devices
· EMI:Unaffected by environmental EMI
·Panel resistance:4 wire resistive model: 300 ~ 900 ohm
欢迎全国各地工业触摸屏维修垂询,更多优惠价格,请通过以下方式咨询!
了解更多的产品,请登录公司官方网站:www.hongyi-touch.com
联系方式:13825015307 QQ:565004903 / 79759504
邮箱:hongyitouchpanel@163.com MSN: boyliuying@hotmail.com
通过中国触摸屏网金牌会员认证
