Technical Parameters
Size
15 inch AU LCD Panel Technical parameters
Resolution
SXGA (1024*768)
Pixel pitch
0.297 mm
Response time
16 ms
Brightness
250cd/m2
Contrast Ratio
300:1
View angle(H/V)
160/150
Active area
305mm*230mm
Physical size
370mm*310mm*60mm
Touch screen(selection)
surface acoustic wave screen, XINKE four-wire and five-wire resistive screen
Five wire Resistance touch screen technical parameters
Touch activation force:10-100g; Light Transmittance: 80%;Single-point touch for thirty five million times; Surface hardness test:3H
Agency Approval
CCC,CE,CB
PC configuration
A8HD Standard industrial mainboard: 1* network Ports; 8*USB2.0 Ports; 1*Audio Output Port; 1*HDMI output port.
Integrated sound card, integrated network card; dual graphics card; Frequency: 500MHZ; VGA Pin Header, HDMI Port, 24b LVDS. Support resolution 1920*1080, AMD Fusion Processor, E350 1.6GHz dual-core; Integrated SIM port, support 3G.
Huntkey 150W; Hard disk Hitachi 320G; RAM Kingston DDR3, 2GB.
Products Functions
No chassis design: using on the desk, the display does not swag when being touched, with good stability.
Convenient angle adjustment: Open the angle adjustment switch; the touch screen can be randomly adjusted in the range of 15°-90°.
Own mould, technical level conforms to international standard, designed with human body engineering and aesthetic principle.
The cover is made by the environment-friendly and fire-proof ABS materials, Safe and reliable, accord with the requirement of environmental protection.
The machine is firm, durable and elegant with modern design.
基本参数
尺寸
15寸AU液晶显示器
最佳分辨率
1024*768
点距
0.297mm
响应时间
16ms
平均亮度
250cd/m2
对比度
300:1
可视角度
160/150
可视面积
305mm*230mm
物理尺寸
370mm*310mm*60mm
触摸屏(选配)
表面声波屏,鑫科四线、五线电阻屏
电阻屏技术参数
操作压力10-100g,透光率 80%,敲击寿命大于三千五百万次,表面硬度:3H
认证规范
CCC,CE,CB
电脑配置
•高清工业主板A8HD 1个网线口. 8个USB. 1个音频输出. 1个HDMl输出
•集成声卡,网卡, 显卡Integrated AMD Radeon HD6310核心,主频500MHZ;
VGA Pin Header, HDMI Port, 24b LVDS. 1920*1080支持. AMD Fusion Processor, E350 1.6G;双核 板载集成SIM接口,支持各规格3G;
•金士顿内存DDR3,2G 日立硬盘320G
产品功能及运用
1.无底座设计,在桌面使用触摸时显示器不晃动,极具稳定性。
2.角度调整方便:打开角度调整开关,触摸屏摆放可以在15度-90度之间任意调整,让您随心所欲。
3.自己开模,工艺水平符合国际标准;采用人体工程学和美学原理设计;
4.外壳采用环保型ABS防火材料制作,安全可靠,符合环保要求;
5.整机美观坚固,简捷、高档大方,极富现代气息。
