Technical Parameters
Touch screen(standard): 70 inch IR touch screen(waterproof, dustproof, anti-explosion)
Use the most advanced IR touch screen,with the resolution of 4096*4096 and light Transmittance 92% above; the touch force is less than 85g; response time is less than 6.5ms; calibration one time, no excursion;Mao`s hardness
test is 7-grade; single-point touch 50 million times ;the response is rapid and the utility time is durable. Agency Approval is CE,FCC,CCC.
Display: 70 inch Samsung LCD panel (16:9)
Use 70 inch LCD panel; Resolution: 1920*1080;field frequency: 60-75HZ;
Pixel pitch:0.807mm; Brightness: 450cd/㎡; Contrast Ratio: 2000:1;Response time:6.5ms; View angle:178°/178°(horizontal/vertical);Active area: 1549.44mm*871.56mm
Working Environment: temperature +0℃-+40℃, relative humidity 10%-90% (relative, non-compression)
Storage temperature: -10℃-50℃
Power Supply: 110-240V,50-60HZ
Physical size: 1650mmX982mmX85mm
Packing size: 1800mmX380mmX1130mm
Total weight: 130kg
Agency Approval: ETL,FCC,CE,RoHS
Products Functions :
1. Waterproof seal standard, effectively protect the touch screen stripe and transducer from touching liquid and dust.
2. Integrated solution for touch function and LCD display, good performance, compact structure, assemble and use very convenient . Double USB and RS232 are available. Not need any other hardware . It’s convenient for users to choose.
3. Higher sensitivity and faster response, click and marking off by touching are very fluent. Long durability; No change to the display size when the products are upgrading.
4. Offer no driver procedure function, plug and play really.
5. High in brightness, contrast ratio, rapid response time and support multicolor, wide viewing angles.
6. Multi-options for assembling including vertical, horizontal. You may assemble it in VESA standard or in your own design.
7. We also can make the products of users’ requirement.
8.Widely used in government, financial institution,transportation, public system, shopping malls, hotels, airports, gas stations, railways stations, post offices, telecommunications, banks,medical institutions, museums, exhibition halls, offices, KTV/VOD entertainments, gaming machines, casino machines and so on. For advertising, entertainment, media instruction information guide and exhibition.
