贝格斯 GAP PAD TGP 800VOS is recommended for applications that require a minimum amount of pressure
on components. BERGQUIST GAP PAD VO Soft is a highly conformable,low-modulus, filled-silicone polymer on
a rubber-coated fiberglass carrier. The material can be used as an interface where one side is in contact with a
leaded device.
BERGQUIST GPVOS Typical Applications Include:
• Telecommunications
• Computers and peripherals
• Power conversion
• Between heat-generating semiconductors or magnetic components and a heat sink
• Areas where heat needs to be transferred to a frame, chassis, or other type of
heat spreader
Configurations Available:
• Sheet form and die-cut parts
