Maximum Resolution 1920 x 1080
Contrast Ratio 1000:1
Brightness 450 nits (No Touch),
250 nits (No Touch),
225 nits (P-CAP)
View Angle H:178˚, V:178˚
Projected Capacitive
Touch 10 points Touch
Touch Screen Interface USB-HID
Display Surface 7H Hardness durable glass
Serial 1 x RJ11 (for optional Remote Key)USB) 1 x USB Type C (Alt Mode for DP video support)
Video Port 1 x VGA, 1 x DP, 1 x HDMI (up to 1920 x 1080 @60Hz)
Audio Port 1 x Audio-Input (3.5 mm Mini-Jack)
Power Input 1 x DC In 12V Jack Power Input
AC Power Adaptor (100VAC ~240VAC, 50/60Hz)
Speaker 2 x 2W Stereo
Housing Color Black
Material Glass, SECC metal
Dimensions (W x H x D) mm 510.96 x 322.28 x 172.98(monitor only)
Net Weight 6.52 kg Gross Weight (kg) 2.80 kg (monitor only)
Carton (W x H x D) mm
615 x 450 x 330 mm
VESA 100 x 100 mm
