Size 15.6” TFT LCD
Maximum Resolution 1920 x 1080
Contrast Ratio 1000:1
Brightness 450 nits (No Touch),
405 nits (P-CAP)
View Angle H:178˚, V:178˚
Touch Screen Projected Capacitive
Touch Points 10 points Touch
Touch Screen Interface USB-HID
Display Surface 7H Hardness durable glass
Serial Port 1 x RJ11 (for Remote Key)
USB Port 1 x USB Type C (Alt Mode for DP video support) 1
Video Port 1 x VGA, 1 x DP, 1 x HDMI (up to 1920 x 1080 @60Hz)
Audio Port 1 x Audio-Input (3.5 mm Mini-Jack)
Power Input 1 x DC In 12V Jack Power Input
Power Supply 50W (12VDC/4.16A) External
AC Power Adaptor (100VAC ~240VAC, 50/60Hz)
Speaker 2 x 2W Stereo 2 x 2W Stereo
Housing Color Black
Material Glass, Plastic (ABS), SECC metal Plastic, l
Dimensions (W x H x D) mm 369.1 x 223.7 x 27.2 (monitor only)
369.1 x 290.5 x 169.4 (with stand)
Net Weight (kg) 1.805 kg (monitor only)
Gross Weight (kg) 2.80 kg (monitor only)
Carton (W x H x D) mm 455 x 315 x 150 mm (monitor only)
VESA 100 x 100 mm
