迈思肯FIS-6300的2D固定式读码器采用最先进的技术,可用于识别2D符号和线性条码。针对高速读码,防静电敏感应用和读取最具挑战的直接零件标记(DPM)都有专用的读码器。
MINI HAWK FIS-6300是一款功能强大的微型影像式读码器,解决了所有行业中的众多数据跟踪和可追溯性需求。它提供了出色的条码读取算法和简单的设置,适用于任何一维、二维或直接部件标记 (DPM) 应用。通过X-Mode技术确保实现可靠的解码,该技术可以读取损坏或难以辨认的符号,而无需进行配置或调整。
凭借简单设置、功能强大的图像处理能力和多种配置,MINI HAWK成为了任何条形码或DPM应用的理想解决方案。
解码速度和读取范围:视型号而异
X-Mode 解码技术
自动对焦
可选的 USB 连接
可选的ESD安全设计
MINI HAWK 3MP: 300万像素分辨率的影像式读码器
MINI HAWK HR: 高分辨率影像式读码器
MINI HAWK HS: 高速影像式读码器
迈思肯microscan FIS-6300选型表
| MINI Hawk 3MP Imagers | |
| Part Number | Description |
| FIS-6300-2013G | MINI Hawk 3, Micro Density, Serial, 5VDC |
| FIS-6300-2014G | MINI Hawk 3, Standard Density, Serial, 5VDC |
| FIS-6300-2015G | MINI Hawk 3, Micro Density, USB + I/O, 5VDC |
| FIS-6300-2016G | MINI Hawk 3, Standard Density, USB + I/O, 5VDC |
| MINI Hawk High Resolution | |
| FIS-6300-4007G | MINI Hawk High Res, Standard Density, Serial, 5VDC |
| FIS-6300-4008G | MINI Hawk High Res, High Density, Serial, 5VDC |
| FIS-6300-4009G | MINI Hawk High Res, Ultra High Density, Serial, 5VDC |
| FIS-6300-4010G | MINI Hawk High Res, Standard Density, USB+I/O, 5VDC |
| FIS-6300-4011G | MINI Hawk High Res, High Density, USB+I/O, 5VDC |
| FIS-6300-4012G | MINI Hawk High Res, Ultra High Density, USB+I/O, 5VDC |
| MINI Hawk High Speed Imagers | |
| FIS-6300-5005G | MINI Hawk High Speed, Standard Density, Serial, 5VDC |
| FIS-6300-5006G | MINI Hawk High Speed, Ultra High Density, Serial, 5VDC |
| FIS-6300-5007G | MINI Hawk High Speed, Standard Density, USB+I/O, 5VDC |
| FIS-6300-5008G | MINI Hawk High Speed, Ultra High Density, USB+I/O, 5VDC |
| MINI Hawk ESD Safe | |
| FIS-6300-1011G | MINI HAWK, Standard Density, ESD Safe, Serial, 5VDC |
| FIS-6300-1012G | MINI HAWK, High Density, ESD Safe, Serial, 5VDC |
| FIS-6300-1013G | MINI HAWK, Ultra High Density, ESD Safe, Serial, 5VDC |
| FIS-6300-1014G | MINI HAWK, Standard Density, ESD Safe, USB, 5VDC |
| FIS-6300-1015G | MINI HAWK, High Density, ESD Safe, USB, 5VDC |
| FIS-6300-1016G | MINI HAWK, Ultra High Density, ESD Safe, USB, 5VDC |
