Type |
36.6" color TFT active matrix, wide LCD |
Display Area |
919.3 (H) x 138.85 (V) |
Optimum Resolution |
1920 x 290 |
Contrast Ratio |
4000 : 1 |
Viewing Angles |
178 (H) / 178 (V) (CR≧10) |
Response Time |
9.5ms (Typ.) |
Backlight |
LED |
Brightness |
700 nits (Typ.) |
Aspect Ratio |
16 : 2.4 |
Panel Surface |
Anti-Glare coating (Haze 1%) |
Power |
Consumption |
45W (Typ.) |
Operation Conditions |
Temperature |
0 ~ 50°C |
Humidity |
20% ~ 90% |
Dimensions(mm) |
960 (W) x 174.35 (H) x 16.9 (D) |
Weight |
Net |
3 Kg |
