1.应用范围
通过控制板上的专用触控芯片,感测人手指等导体在触摸屏表面的电容变化,计算多点坐标值并输出到终端产品主机实现电容触摸屏之应用。
2.产品特征
Item |
Spec. |
1 |
Touch Panel Size |
43inch |
2 |
Outline Dimension |
972mm*570mm |
3 |
View Area |
941.18mm*529.42mm |
4 |
MDSN Film |
125umPET 16ohm |
5 |
OCA1 |
100um |
6 |
OCA2 |
100um |
7 |
Cover Glass |
3mm |
8 |
Touch module thickness |
3.45mm |
3.环境特性
Item |
Temperauture |
Humidity |
operating condition |
-25~60℃ |
20%-90%RH |
stroage condition |
15℃~30℃ |
40%-70%RH |
4.电气特性
Item |
SPEC |
Remark |
Report Rate |
80Hz |
No in noise |
Accuracy & Linearity |
Full screen < +/-5mm |
9mm finger |
Operation Voltage |
4.5V~5.5V |
Sensor Channel |
54Tx * 96Rx |
Sensor Pitch |
9.85mm * 9.83mm |
Max resistance of silver |
Tx silver:<4kΩ;Rx silver:<2kΩ |
Tx + Rx <20kΩ |
通过中国触摸屏网金牌会员认证
