材料机结构可按照客户要求提供图纸或者样品制作,钨钢,陶瓷,模具钢不锈钢,钛合金 黄铜 压头
钛合金热压头采用日本进口的钛合金TC4,材料的组成为Ti-6Al-4V,属于(a+b)型钛合金,具有良好的综合力学机械性能。 TC4的强度sb=1,012MPa,密度g=4.4×103。产品广泛用于热压设备/脉冲热压机设备,钛合金热压头经数控铣削-精磨-数控钻孔-慢走丝线切割-精磨刀口等工序制成,加工出来的产品具有升温快,温度误差小,耐磨,耐高温,耐腐蚀,受命长等特点。先进的焊接工艺,焊点牢固,不脱落。
All kinds of constant temperature machine/pulse hot-pressing machine, hot melt machine/laminating machine production of the cutting tools
Machine structure can provide the drawings or sample production according to customer's requirement, tungsten steel, ceramic, steel stainless steel, titanium alloy brass head
Heating head, Japan imports of titanium alloy TC4 titanium alloy, the material composition for Ti 6 al 4 v, belong to the type of titanium alloy (a + b), has the good comprehensive mechanical properties.The strength of TC4 sb = 1012 MPa, density g = 4.4 x 103.Products are widely used in thermal equipment/pulse hot-pressing machine, extrusion head by numerical control milling titanium alloy - fine grinding - CNC drilling - wire cut fine whet knife mouth - process, product processing, have to heat up fast, the temperature error is small, wear-resisting, high temperature resistance, corrosion resistance, long ordered etc.Advanced welding technology, solder joint is firm, do not fall off.
压头规格
