3M9119-100,3m9119-140双面胶带3M9119
型号:3M9119
双面聚酯胶带9119系列
规格:1050MM*100M
3m9119-50--0.05mm
3m9119-85--0.085mm
3m9119-100-0.1mm
3m9119-140-0.14mm
特点与应用:耐高温性能优良。两面不同的粘性,一面高粘性,适合永久固定,另一面中粘性,适合重新定位的需求。
厚度是同类产品中最薄的一种,特别符合薄型设计的要求。主要用于元器件的粘接等。
3M9471LE,3M9472LE,3M9671LE,3M9672LE, 9475LE,9495LE,;7952MP,3M966,3M9461P,8008,3M 8018,8004,988T,55230,55231,55256,55257, 3M9119,55280
3M55258,cip66,cip60,cip-47,cip-36,cip-01,cip-02, #9795,#9795B,966, ST416P,9079,#9609,#7303,#7816,7818,#7881
3M55235,55230,6408,9080,3M9080A,9448HK,3M9448A,3M9485PC,3M9495MP,9472,9473,9482,9485PC,9490LE,9495MP,9495B,9495LE,9500PC,9505,9552,9589,
9665,9667,300LSE,9671LE,9672LE,9690,9690B,9692,9695,9703,9713,9731,9752,9755,9820,9828,9885,9890,9925XL,3M9725,3M9731;3M300LSE,
