供应3m86420胶带
规格:584mm*66m
苏州思美扬公司主要代理3M胶带 德莎胶带
3M铝箔胶带 3M425,3M427,3M363,3M471,3M5702,3M5421,3M5423,3M5425,3M5491, 3MAL35FR,3MCN3190,
PTFE胶带#5490,5480,5481,3M 60,61; 8952,#1020,#1115,#1040, 411,
3M3M保护膜2124C,2104C,#3K04,2K10,332, 331s,331T,336,361,375,371,373,401,411,415,420,
PU 3M 8591,3M8592,8671,8672,犀牛皮,
3M水溶性胶带#900B,#9069,#3M9996J,#3M913,#906,9974,9979,900B,906,#9996,#9979, 3M R3227,3M r9996,
3M搭扣,3M蘑菇扣 3M SJ3551,3M sj3550, 3M sj4570, 3M sj3560, 3M sj3540, #SJ3526,3527,
封箱胶带301,309,#3M371,#3M375,#3M373,
3M标识胶带, 3M471, 3M764,cip47,
3M斑马胶带:3M5702,3M 766,
美纹纸胶带 3M200,3M2396,3m2090
纸胶带:#3M232,#2307,2308,2309,200,3M 2214, 3M244,2444,#2364,3M 250,3M2142;
3M布基胶带#3M6969,3939,3M3900,
Kapton3M高温胶带,7413T,3M 7413D,3M5413,7419,5419,2132,92,42,40,cip36,3M547,
硅胶带,SMT用,
3M热熔胶带 3M 588,3M615,615s,3M 690,3M583;
3M纤维胶带,#8898,#3M 898,3M893,3M 8915,
3M玻纤胶带2517,336,8952,8402,950,8902,367FR, 369FR,
3M3M电气胶带,3M绝缘胶带,5,3M 10,#11,27,40,42,#69,#60,#92,1350,1554,61,62,12,40,42,54,56,74,1298, 1318,79,90,94,44,46,1276,1312,1339,1170,1181,1194,1245,1345,1190,AL-35FR,
3M防水胶带 77,23,3M2228,3M2517,2157,13,24,70,130C,2220,2229,2166,1500,1600,1712,1700,1750, 33+,35,88,22,66R,2000,22, #610,#600,810,811,#8915,#5413,#5451,
3M柔印胶带3M1015,3M 1020,1120,1115,1040,1614,1640,1815,1820M,1915,1920M,
3M贴版胶带 3M411DL,3M 414DL;3M1015,3M1020,3M244,3M583,3M425,SJ3550,SJ3551,3M 1181,1190,1205,3M 1245,1170,1281,1285,1290,3M1318,1345,3M 1350,
3M1280,200,2214,244,213,2310,214,232,2307,2308,2309,243J,217,236,241, 2517,250,
3M胶水DP100,DP420,190,2216,2214,125DP,DP190,CA40H,TE230,TE100,200, LC1110,2000NF,1357,5,10,4693,826,2262,4475,847,1300,4799,560, 847,2214,
3M胶水,3M黑胶,3M结构胶,3M喷胶:3M4799,3M4475,3M4550,3MSF-7533,3MDP-100 ,3MDP420,3MDP460,3MDP-190,3MDP-818,3MDP-270,3M3748Q,3M3779,3M3764
1、 Scotch-WeldTM 结构胶
3M1838,3M2216 双组份环氧胶:双组份环氧胶粘剂,高强度,高耐冲,适用于多种场合。
3M1386,3M2214 单组份环氧胶:单组份环氧胶粘剂,需低温保存,高温固化,优异的粘接性和耐温性能,适用于特殊要求的高强度粘接。
3MDP-100,3M105,3M110,3M125,3M190,3M270,3M420,3M460,3M818,3M805
3MDuo-Pak双组份胶: 预先包装好的双组份粘接剂。使用3M EPXTM施胶系统, 操作简便、快速,使工作效率成倍提高,降低混合时的浪费,节省成本。
2、 ProntoTM 快干胶
3MCA-4,3MCA-5,3MCA-7,3MCA-8,3MCA-9,3MCA-40H,3MCA-50Gel,3MCA-100快干胶:这些单组份的α羟基丙烯酸的胶粘剂,在室温无催化剂条件下可快速达到处理强度。
3、 Scotch-GripTM 和 FastbondTM 胶水
3M30NF,3M100,3M2000NF 水溶性胶:3M公司在水性胶粘剂方面有很多独到的技术。3MFB30,3M100,3M2000是3M公司专为大面积粘接而设计,操作快捷,安全无毒,符合环保的要求。这种胶水有很高的
含量,覆盖面积大,是一般溶剂型胶粘剂的数倍以上
3M5,3M10,3M1357高性能接触胶:溶剂型高性能接触胶。强度高,易操作。
3M847,3M1300橡胶密封件胶:特制的橡胶型胶粘剂,适用于粘接多种橡胶,有极高的强度。其中3M847胶粘剂含有酚醛树脂,加热后可达到半结构强度。
3MIA-34,3M4799,3M4550 工业胶:多用途的工业胶粘剂。粘接范围广泛,适用性强。
3MIA-34 特别适用于粘接保温材料和轻质材料,使用方便,即可滚刷,也可喷涂,粘性大,干燥快,而且具有很大的覆盖面积。
3M4799 特别适用于粘接家电的显示窗口,强度高, 粘性持久,而且溶剂不腐蚀丝印油墨。
3M4550 适用于粘接多种表面,粘接快速。
3M1099,3M2262,3M4475,3M4693塑料胶:3M有多种独特的塑料胶粘剂,适用于粘接多种塑料材质,如PVC,PC,PE,PP,ABS等
4、 喷胶
3M75,3M77:独特的颗粒状,雾状喷射喷胶。高固含量,大覆盖面积。
3M75 号喷胶是不干型喷胶, 胶性强度适中,胶性持久,可反复粘贴。特别适用于需要重复定位,粘贴的场合。
3M77 号喷胶是超强力多用喷胶,高固含量,大覆盖面积,经久耐用,适用于许多场合的使用。
3M72,3M74,3M76,3M80,3M90:独特的条状喷胶,胶性各个不相同,喷射状态可以调节,适合多种场合。
5、 丝印胶
3M6010,3MSP 7533丝印胶: 3M可丝网印刷用压敏胶具有耐热,耐潮性能,可丝网印刷,图形质量高,与双面胶带相比成本低,适用性强,是水分散型胶粘剂,无有害气体,不燃烧,储存方便;不对油及
底材产生影响
6、 热熔胶
3M3748,3M3762,3M3764,3M3779,3M3792 热熔胶:3M热熔胶系列有多种不同树脂基材的产品,可广泛用于包装、家具制造、电子工业中。不同产品可满足不同工业生产要求。
3M3762适用于食品包装行业,有FDA认证
3M3748,3M3764,3M3779可用于电子行业,有美国UL94认证
3M3792适用于家具制造业
3M胶带,3M410,415,444,465,3M 467MP,468MP,469,665,666,920XL,924,926,927, 950,966,969,471,500,
3M测试胶带 610,810,3M 600,3M665,3M610;3M810,3M850,850B,3M 851,3M853,3M4981,3M 8333,3M 8401,3M 8402,3M 8411,3M8901,3M8902,3M8952
3M拼接胶带UHMW-PE, 3M 5421,3M5423,3M5425,5430, PTFE 3M5451,3M5453;3M5461,3M5491,3M5480;
3M脚垫,SJ5302,5312,SJ5816,SJ5608,
3M粘扣带SJ3562,SJ3527,SJ3440,SJ3441,sJ3540,3541,SJ3550,sj3551,
3M双面泡绵胶带4004,3M4008,3M4016,3M 4026,3M 4032,CIP66,4052;4085,3M4416,3M4432,3M 1600T;
3M VHB胶带,4905,4910,3M4920,4921,3M4926,4929,3M4930,3M4932,4936, 3M4941, 3M4914,3M 4945,4949,3M4950,3M4951,3M4952,4955,4959,4962,4965,4974,
4951,3M4210,3M5608,3M5612,CP5008,,3M5314, 5392,4604,3M4608,3M4611,4615,4630,4609,4627, 3M5925,4008,4032,4026,4016,3M5952,4979,4993,5408,5552,3M5962,3M RP32,3M
RP45,49523M9460,3M9469,3M9473,
3M双面胶带模切 ,透明VHB 3M 4905,3M 4910;
3M幕墙双面胶带G23F,G23B,4972,
3M导电胶带,3M7303,7951MP,7953MP,7979, 9703,3M9709 ,
3M无基材双面胶带,9045MP,9056,9057,9059,9185MP,9415,9420,9425,9429, 9449,9458,9459W,F9460PC,9461,9462,9465,9469,9471, 3M9500PC,
3M转移胶膜
55235,55230,6408,9080,3M9080A,9448HK,3M9448A,3M9485PC,3M9495MP,9472,9473,9482,9485PC,9490LE,9495MP,9495B,9495LE,9500PC,9505,9552,9589,9665,9667,300LSE,9671LE,9672LE,9690,9690B,9
692,9695,9703,9713,9731,9752,9755,9820,9828,9885,9890,9925XL,3M9725,3M9731;3M300LSE,3M 9471LE,3M 9472LE,3M9671LE,3M9672LE, 9475LE,9495LE,;7952MP,3M966,3M9461P,8008,3M
8018,8004,988T,55230,55231,55256,55257, 3M9119,55280,55258,cip66,cip60,cip-47,cip-36,cip-01,cip-02, #9795,#9795B,966, ST416P,9079,#9609,#7303,#7816,7818,#7881,
3M3M标签,#7811,7812,7603,#3921,#3M 7810,#850,
PCB胶带616,910,920, 3M5557 ,3M7815,3M7816;8402,8401,332T,5419,SuZhou DaTong,7413,8141,8142, 9448,9448B,3M55230,3M 55235,55256,8008,8018,8608,988T,9888t,9075,9070,6408;
电工胶带 3M 1500,3M 1600,1700,3M1712,
防静电胶带 3M 40,42;
电气胶带 3M 11,3M54,3M56,3M 69,3M 92,98c-1,
3M导热胶带 3M8805,3M8810,8215,
3M汽车胶带 4229P,4211,4210,4211,4215,4016,4615,4611,4609,5314,4124,CP5008,cp5012,4218,GT6008, CP5108,PT1100,PT1500,RT8016,
