- 产品描述:
●铆钉直径6.0—12.0mm●径向铆接路径●由于铆接侧向力很小,因此可以铆接电木,陶瓷或塑料件●可单独使用也可组成完整的工作站●可连接Baltec RC10控制器●Baltec双手启动开关●气动组件●工装长度可根据需求而变
BalTec SmartLine
Dimensions and weights – Stand Alone.ModelABCDJQSTUVWSN 17074-225126-156200-351744-895260Ø 1385-309075130405SN 22039-195146-186185-341749-905260Ø 1385-709075130405SN 27078-228166,5245-395867-1017320Ø 1625-40100120185525ModelXYZkgSN 170125115Ø 7575SN 220125115Ø 7590SN 27014786Ø 125170Dimensions and weights – Head Only.ModelBDEFGKLSMNPSNE 170126-156580173126108-1381791105-3010031Ø 103SNE 220146-18662018515098-1381791105-4010031Ø 103SNE 270166,5692211175145-1852061255-4013442Ø 185ModelQRYkgSNE 170Ø 138Ø 7511530SNE 220Ø 138Ø 7511545SNE 270Ø 162Ø 16217560
BalTec Radial riveting machines SmartLine
Performance of each modelModelSN 170SN 220SN 270Rivet shank *) max. (mm)Ø 6Ø 8,5Ø 12Pneumatic pressure in BAR2 - 62 - 62 - 6* Riveting force in kN61217Tool stroke in mm5 - 305 - 405 - 40Riveting time in sec.0,2 - 5,90,2 - 5,90,2 - 5,9Weight in kg7590170* Steel 370N/mm2 (St. 37)
* Maximum riveting force in kN
Subject to technical changes彤威科技--
