faytech´s resistive Touchscreen Monitor series
Experience a new working environment with faytech´s 15”-22” Touchscreen Monitor Series. These monitors are packed with features and connectors that make them perfect in any industrial or commercial application. Each Touchscreen Monitor is built using an industrial LCD panel with backlighting (40,000+ hour lifespan), 5-wire resistive touch and anti-glare coating to enhance the user’s performance and of course includes faytech’s 100% guarantee of no defective pixels. The 15”-17”-19” models have VGA and DVI-D connectors, with additional S-Video and HDMI connections added to the 22” version. Each monitor comes with its own desktop stand, and screw patterns on the back for VESA-100 mounts, so it can be used in a variety of configurations in industrial and commercial environments.
The high resolution support (e.g. 768p, 1920×1200 pixels) of these faytech touchscreens make them the perfect choice for a wide variety of applications including use in POS systems, as control panels in the industrial area, in kiosk systems, for machine control, in the office and in many other areas.
The integrated touch panel is robust and accurate. The touch function is quickly established via the USB port of your PC, and industrial users can connect the touch function through the serial port. faytech includes touchscreen drivers for popular Microsoft (CE, WinXP, Vista), Mac and Linux operating systems. For Win7, Win8 and Win10 operating systems no driver installation is needed because the MER4485 chipset used in faytech´s in-house designed touch controller supports Login using virtual keyboard and immediate use of windows gestures making starting and using Windows 8 or 10 incredibly easy.
Customization is available for project customers (e.g. higher brightness, brightness sensor, IP protection classes, integrated power supply, webcam, scanners, printers, capacitive and SAW touch panels, etc.)
LCD-Panel
| Screen diagonal (Inch/cm): | 19/48.26 |
| Display active screen size: | 41.22 x 25.91 |
| reflection type (glare / anti glare) | Anti Glare |
| Aspect ratio: | 16:10 |
| Physical resolution: | 1440×900 |
| Maximum showable resolution (TPCs: external): | 1920×1200 |
| Colours displayed: | 16.7M |
| Brightness (cd/m2): | 250 |
| Contrast: | 1000:1 |
| Typical reaction time Tr/ Tf (ms): | 1.5/3.5 |
| Visual Angle horizontal/vertical (°): | 170/160 |
| Backlight / Backlight Lifetime (hours): | LED / 40,000 |
Touch Panel+Touch-Controller SPEC 5-wire
| resistive 5-wire / touchpoints | ● / 1 |
| Touch Controller chipset | EETI MER4485 |
| USB-Touch-connector (PC internal connected): | ● |
| Serial-Touch-connector (PC/IP65-models optional) | ● |
| Touch Panel-driver: | Windows, Linux, Android, Mac |
| 10 million in 1 location without failure | ● |
| Response time Touch Panel (ms): | < 10 |
| Surface hardness: | 3H |
| Surface treatment: | anti glare |
case
| case material | ABS-plastic case |
| finish | black or silver, powdered (other colors optional) |
| IP-protection class | IP40 |
| case (cm) L x W x H: | 44.8 x 35.3 x 5.3 |
| package carton single (cm) L x W x H: | 51.0 x 44.0 x 18.5 |
| Net weight (kg): | 4.98 |
| gross weight (kg): | 6.60 |
| VESA-100 on the back | ● |
