faytech 飞帆泰10.1英寸嵌入式触屏电脑 德国品质
品牌: faytech
最后更新: 2015-12-03 10:01
 FT10A20M400W1G4GCAP_1
FT10A20M400W1G4GCAP_2
FT10A20M400W1G4GCAP_4
faytech´s embedded capacitive Touch-PC
Available in two standard versions with just W-LAN or with W-LAN, Bluetooth 4.0 and GPS integrated, POE-plugIn and OTG-port added, it is faytech´s most cost effective but still powerful DualCore solution for Linux and Android projects. Even WinCE-BSPs are available for project partners. Now available in faytech´s embedded capacitive TPC series or also as single embedded system. faytech's Embedded Touchscreen Series is the cost effective solution for machine control, automation, and digital signage. By including pre-installed Android 4.2, Android 4.4 or Linux, a powerful Allwinner A20 Dual Core CPU, Mali400MP2 graphics chipset, numerous interfaces such as USB, serial, network, TTL / UART, Mini-PCIe, HDMI, VGA, GPIO, LVDS and extended DC –IN, faytech's new Embedded Series is the right choice for reliable, industrial solutions.
Each embedded system comes standard with 1 GB DDR3 RAM and 8 GB flash memory and includes a S- ATA connector as well as SD card slot for further hard disk expansion. Wi-Fi is integrated, and over MiniPCIe the systems can be upgraded to 3G + GPS using the available SIM card slot.
The touch features capacitive 10-finger multitouch panels, Anti Glare chemical etched treatment and optional bonded to the LED backlighting panels, backed by faytech's warranty for pixel accuracy (A + quality).
The design of the Embedded Touchscreen series follows the application: flat easy to integrate IP65 front and stable rear housing with VESA-100 mounting for fixing / integration.
faytech 's new Embedded Touchscreen Series is our most cost-effective solution for intelligent machine control, and like all faytech’s reliable touch devices built for precision and durability.
Features
  • Allwinner A20 Cortex™ DualCore Processor
  • GB DDR3 RAM; 8 GB NAND FLASH
  • Cortex™ A7 Chipset
  • Full HD Resolution – 1920 x 1080
  • Android 4.2, 4.4 & Linux Support, WinCE optional
  • Optional Bluetooth & GPS
  • Integrated HI-FI 100dB Audio Codec, 2x 6W amplifier
LCD-Panel
Screen diagonal (Inch/cm): 10.1/25.65
Display active screen size: 21.7 x 13.6
reflection type (glare / anti glare) Anti Glare
Aspect ratio: 16:10
Physical resolution: 1280×800
Colours displayed: 262K
Brightness (cd/m2): 400
Contrast: 800:1
Typical reaction time Tr/ Tf (ms): 15,15
Visual Angle horizontal; vertical (°): 178/178
Backlight / Backlight Lifetime (hours): LED / 15,000
capacitive Touch Panel+Touch-Controller SPEC
projected capacitive / touchpoints ● / 10
Glass/Sensor-Structure: Glass-Glass (GG)
USB-Touch-connector (PC internal connected):
Serial-Touch-connector optional
Touch Panel-driver: Windows, Linux, Android, Mac
touch panel survives how many touches (Touch-life-contacts) unlimited
Response time Touch Panel (ms): < 10
cover glass: strengthened glass
Surface hardness: 7H
Surface treatment: anti glare chemical etched
case
case material Rubber front and ABS backcase
finish black or silver, powdered (other colors optional)
IP-protection class Front case IP65
case (cm) L x W x H: 27.6 x 19.2 x 3.4
package carton single (cm) L x W x H: 34.5 x 13.0 x 31.5
bulk carton (5pcs in one) L x W x H (cm): 35.5 x 67.0 x 33
Net weight (kg): 2
gross weight (kg): 2.9
VESA-100 on the back
faytech 10.1寸电容屏触摸显示器 德国品质 faytech 32寸 工业电脑 触摸一体机 德国品质 faytech 32寸IP65 工业触摸显示器 德国品质 faytech  15寸铝壳 触摸显示器 德国品质 faytech  12.1寸IP65 触摸显示器 德国品质 faytech 10.4寸 IP65触摸显示器 德国品质 faytech  飞帆泰10寸IP65 触摸显示器 德国品质 faytech 飞帆泰8英寸IP65 电阻触摸显示器
