项目:JLT18003A
A.产品概述(Description of products)
- 产品型号(Product model):JLT18003A
- 分辨率(Resolution):128*160
- 面板尺寸(Panel size):1.77英寸
- 面板品牌(Panel manufacturers):CMO.台湾奇美
- 驱动芯片(Drive chip):ILI9163C.ST7735R
- 接口数量(Interface PIN):20PIN
- 接口方式(Interface type) :并行接口(8位)
- 活动区域(Active area):28.03*35.04 mm
- 产品厚度(thickness):2.25 mm MAX
- 触摸类型(Touch type):无触摸(No Touch pad)
B.产品图片(Product pictures)
C.接口定义( Interface definition)
| 引脚序号PIN No. | 引脚名称Symbol | 作用描述Description | 备注Notes |
| 1 | LEDK | Cathode of Backlight(背光负极) | |
| 2 | LEDA | Anode of Backlight(背光正极3.0-3.4伏供电) | |
| 3 | GND | Ground(接地脚) | |
| 4 | VDD | Power supply for LCM(屏电源供电脚 2.8-3.3V) | |
| 5-6 | NC | No connection(空脚) | |
| 7 | CS | Chip selec pin (“Low” enable)(屏驱动芯片片选脚,低电平有效) | |
| 8 | RESET | LCM Reset pin(屏复位脚,低电平复位) | |
| 9 | RS | Register selec pin(指令/数据寄存器选择脚)RS=’1’: Display data.(RS=’1’:选择数据寄存器)RS=’0’: Command data.(RS=’0’:选择指令寄存器) | |
| 10 | WR | Write control pin(写控制脚) | |
| 11 | RD | Read control pin(读控制脚) | |
| 12-19 | DB7-DB0 | Data Bus(8位数据线) | |
| 20 | GND | Ground(接地脚) |
详细规格书及配套代码.应用资料.可直接咨询【晶力泰】销售人员。
