特点:
设备采用高精度恒温加热系统确保热压头温度一致稳定,精确的自动卷带和切割系统有效的保证产品的贴附精度。
Equipment using high-precision temperature heating systems to ensure the accuracy of the thermal head attached to a stable temperature consistent, accurate and cutting system with automatic volume effectively guaranteed products.
用途:
适用于单层或两层ACF的剥离、切割和贴附;将ACF贴附于LCD、LILM、PCB和FPC是其他机上。
Suitable for single or two-ACF peel, cut and attached; the ACF attached to the LCD, LILM, PCB and FPC is on the other machine.
技术参数:
电源:AC220V±10%,50Hz,600W
工作环境:20℃+/-5℃,干净,无尘,洁净房
工作气压:0.5~0.7Mpa、干燥气源
加热方式:恒温加热
工位:单工位/平台进出
外形尺寸:L:700mm W:70mm H:1500mm
热压头尺寸:L:5-70mm W:1~8mm(可订做)
适合尺寸:1.77”~7”
ACF贴附精度:X≤±0.2mm Y≤±0.1mm
ACF宽度:0.8~8mm
工艺流程:人工上料→真空吸附→启动→平台进出粘贴→ACF剥离→下料
