T1200卧式离子风机,离子风覆盖宽度达到140CM,可吊挂及工作台平放使用,适用于大面积宽范围除静电,属电子类。可调节离子风量,内置高压发生器。
Specification(技术参数)
Operating Votage(工作电压) |
110V/60Hzor220V/50HZ |
Power(功率) |
40W~80W |
Operating Temperature(操作温度) |
-10~50℃ |
Size(尺寸) |
1280mm×215m×190mm |
Weight(重量) |
14.5KG |
Air volume(风量) |
140~120CFM |
Lon Balance(离子平衡) |
0V±10V |
Air coverage(气流面积) |
150cm×360cm |
Decay Tdst Results(测试结果)
Testing Conditions(测试条件) |
Testing voltage(测试电压)1Kvto100V operating voltage(操作电压)110/220V Temperature(操作温度22℃ |
Distance(距理) |
300mm |
600mm |
900mm |
Left(左) |
+0.9s |
+2.1s |
+2.9s |
-1.1S |
-2.1s |
-3.3s |
Center(中心) |
+0.9S |
+1.6S |
2.0s |
-1.0S |
-1.9S |
-2.5S |
Rinht(右) |
+0.9S |
+1.8s |
+2.5S |
-1.1s |
-2.1s |
-2.9S |
