ST108A卧式离子风机,其在ST104A的基础上增加一个离子风出风口,使其离子风的覆盖范围扩大一倍,属电子类。可调节离子同量,内置高压发生器。
Specification(技术参数)
Operating Votage(工作电压) |
110V/60Hzor220V/50HZ |
Power(功率) |
26W~60W |
Operating Temperature(操作温度) |
-10~50℃ |
Size(尺寸) |
890mm×215m×190mm |
Weight(重量) |
10.2KG |
Air volume(风量) |
90~120CFM |
Lon Balance(离子平衡) |
0V±10V |
Air coverage(气流面积) |
100cm×240cm |
Decay Tdst Results(测试结果)
Testing Conditions(测试条件) |
Testing voltage(测试电压)1Kvto100V operating voltage(操作电压)110/220V Temperature(操作温度22℃ |
Distance(距理) |
300mm |
600mm |
900mm |
Left(左) |
+1.1s |
+1.6s |
+2.8s |
-1.2s |
-2.0s |
-3.0s |
Rinht(右) |
+1.0s |
+1.8s |
+2.8s |
-1.2s |
-2.1s |
-3.1s |
