ST103A悬挂离子风机,其按交流型静电消除器原理设计而成,属电子类。适用于消除空间静电。可调节三个离子风出口风量,内置高压发生器。
Specification(技术参数)
Operating Votage(工作电压) |
110V/60Hzor220V/50HZ |
Power(功率) |
45W~111W |
Operating Temperature(操作温度) |
-10~50℃ |
Size(尺寸) |
1100mm×184mm×110mm |
Weight(重量) |
12.8KG |
Air volume(风量) |
120~330CFM |
Lon Balance(离子平衡) |
0V±10V |
Air coverage(气流面积) |
40cm×120cm |
Decay Tdst Results(测试结果)
Testing Conditions(测试条件) |
esting voltage(测试电压)1Kvto100V operating voltage(操作电压)110/220V Temperature(操作温度22℃ |
Distance(距理) |
300mm |
600mm |
900mm |
1200mm |
Left300mm(左300) |
1.9s |
2.5s |
5.1s |
8.6s |
Center(中心) |
1.3s |
2.3s |
4.13s |
8.3s |
Right300mm(右300m) |
1.8s |
2.6s |
4.8s |
8.5s |
