ST102A悬挂离子风机,其按交流型静电消除器原理设计而成,属电子类。适用于消除空间静电。可调节双离子风量,内置高压发生
Specification(技术参数)
Operating Votage(工作电压) |
110V/60Hzor220V/50HZ |
Power(功率) |
21W~62W |
Operating Temperature(操作温度) |
-10~50℃ |
Size(尺寸) |
600mm×90mm×170mm |
Weight(重量) |
7.8KG |
Air volume(风量) |
80~220CFM |
Lon Balance(离子平衡) |
0V±10V |
Air coverage(气流面积) |
40cm×90cm |
Decay Tdst Results(测试结果)
Testing Conditions(测试条件) |
esting voltage(测试电压)1Kvto100V operating voltage(操作电压)110/220V Temperature(操作温度22℃ |
Distance(距理) |
300mm |
600mm |
900mm |
1200mm |
Left300mm(左300) |
1.3s |
2.4s |
2.8s |
4.9s |
Center(中心) |
2.8s |
1.7s |
3.2s |
3.6s |
Right300mm(右300m) |
1.2s |
2.1s |
3.0s |
4.5s |
