尺寸/Size |
12.1 " |
分辨率/Resolution |
800×600/1024×768 |
亮度/Brightness |
330/150cd/M² |
色彩/Color |
16.2M/255K |
对比度/Contrast |
450:1 |
触摸系统/A touch system |
MapleTouch-J五线军工电阻触摸屏(单点可达3500万次) (有USB/RS232触摸卡可选) MapleTouch-J five line military resistance touch screen (single point up to 35000000 times) (USB/RS232 touch card optional) |
系统参数/System parameters |
主板/Host board |
Mini-ITX MP-1037U |
处理器/CPU |
Intel® Celeron® Processor 1037U 1.8G |
内存/RAM |
2GB DDR3-1333 SDRAM |
芯片组/Chip set |
Intel® NM70 Express Chipset |
SATA |
1×SATA II 3GB/s HDD/SDD/1×SATA III 6GB/s HDD/SDD/1×M-SATA |
LAN |
1×Realtek RTL8111DL (100/1000Mbps) |
Audio |
Realtek ALC887 HD Audio Codec integrated |
储存体/Hard disk |
1×2.5 " SATA II HDD-320G/SSD-32G |
输出/入端口 The output/Input port |
3*RS232 1*LAN 4*USB 2.01*VGA 1*LPT1*PS2(KB/MS) |
扩展总线/The expansion bus |
1×PCI Express×1 1×Mini PCIE |
工作环境/ Work environment |
操作温度/ Operating temperature |
-10~60℃ |
储存温度/Storage temperature |
-30~80℃ |
操作湿度/ Operating humidity |
20~85% |
敲击和碰撞/ Knock and collision |
Operating 20G(11Ms),Non-operating 320G with HDD Operating 80G(11Ms),Non-operating 32G with SSD |
其它/Other |
电源输入/Power Input |
100-240VAC ~ 50~60HZ 1.5A |
电源输出/Power output |
12VDC 5A MAX |
材料结构/Material structure |
钣金 Sheet metal |
安装方式/Installation mode |
面板、架式、壁挂式、台式、VESA悬臂安装 Panel, type, hanging type, desktop, VESA cantilever installation |
净重、毛重/ Net weight、gross weight |
3.35/3.5kg |
体积规格/Size specification |
300 mm*238mm*43.5mm |
